Question about 3Com OfficeConnect Wireless Router
Router stops responding with red alert light turned on
New 3Com® OfficeConnect® ADSL Wireless 108 Mbps 11g Firewall router (3CRWDR200A-75). Randomly stops responding. Download last firmware but with no help. Some setting problem? Looking for help!
  • 6 more comments
  • Anonymous Nov 03, 2007
    I got exactly the same problem!
    I'll try install the firmware, thanks.
  • tanumano Nov 17, 2007
    Router stops responding with red alert light turned on problem
  • fiona_ru Nov 25, 2007
    Router stops responding, red led "alert" is on.
    No connection with router on http.
    Restarting the router is by disconnecting from power and after router reboot solves the problem
  • Anonymous Jan 05, 2008
    Just disable SPI, Hacker Pattern and Anti-Dos Firewall and everything works fine!
  • abo_el_ mer Feb 09, 2008
    Hi i have a problem with my wireless router
    wireless router 3com 3crwdr200a-75 stops from entering to the net. I power it off and switch it on and it will work normally. But that happens more than 5 times a day, and each time i have to switch off and power it on !!
    any solution ??
  • Tony_lunna Mar 01, 2008
    I had a similar problem - alert light on and modem locked up, no wireless or lan access. I have updated to the latest 3com firmware 3.0.1 But, beware : after the upgrade, it is necessary to do a hard reset as follows: power off, press and hold in the reset button on the back panel, power up but keep the reset button held in for 30 secs, release the reset button and allow the modem to complete its boot up. Once this has completed, power cycle again without pressing the reset button. This is the advice I was given from 3Com. The soft reset from the menu should not be used. All settings will be back to defaults, including the lan ip address (192.168.1.1). Tony.
  • jbmaciel May 05, 2008
    I have the same problem. I am using 3.0.1 firmware.
  • Anonymous May 06, 2009
    i have the same problem, red alert and router freez
Hi. i have a 3com officeconnect dual speed hub5 and i would like to know to to access it. i tried with the ip from default gateway, but i got no access. i also have no manuals from it. Any clu how to access its setup? thanks
Posted on Mar 14, 2008
Guys,
There is a new Firmware version 3.1 Beta release that is fixed lots of problems, though this version is unofficial and not yet released on 3Com website.
Download link: [url]http://aragostabbs.altervista.org/request.php?37[/url]
Enjoy!!!
Version & Build Date
3.1/ 2007/10/17
Modification
1. DSL code base update to 3.10.02.
2. ADSL phy driver version : A2pB022g.20H.
Bug Fixed
1. Java script error in Internet Setting page.
2. Dyndns and No-IP are Unworkable. Can not update server ip address.
3. Some gif link can not finish after added DDNS configuration.
4. RIP seems unworkable, Can not enable this function.
3.0/ 2007/9/24
Modification
Bug Fixed
1. ‘%’ issue in username and password.
2. DMZ cannot be removed.
3. Internet WAN add/modify UI error
4. IPSec unworkable. Can not to add and save IPSec Configuration.
5. Can not edit and cancel Port Mapping Configuration.
6. Change login timeout value, does not need check a password.
7. ALG Link unworkable(Removed).
8. Dyndns and No-IP are Unworkable. Can not update server ip address.
9. It does not arrive at the DDNS service which I set. Same issue in the TZO.
10. RIP seems unworkable, Can’t to enable this function.
11. If input ASCII value excluding 0-9 into year field, Current time will save and change to the “1970 0:00:00”.
12. “URL filter” Priority must higher than “PC Privileges”.
13. Content filter seems unworkable.
14. SIP Filter seems unworkable.
15. Some attack can’t be “Intrusion Detection” blocked. Ex: syn flood, ping flood, UDP flood.
16. At Internet Settings -> WAN page, if i enable the option "PPPoA" in Connection Parameters table, the IP Address field will display "undefir".
17. PPPoE does not work.
18. In WAP-PSK When the input value includes?’?, Encryption Function will crash.
19. A “Channel” item of Device Info information is not displayed normally.
20. Channel range is not correct.
21. Can not to disable “Radio” Function.
22. If DHCP lease table status is an “Expired”, a table will has some wrong.
2.9B_ A_SH_DATA_PUMP_20H/ 2007/9/13
Modification
Bug Fixed
1. Virtual server cannot be removed.
2. ROUTER ADSL PC Anywhere will not pass.
3. Java script error on E-mail alert function.
4. Java script error on Internet WAN setting function.
5. Java script error on WPA-Radius server function.
6. Add Jordan in country list.
2.9/ 2007/7/20
Bug Fixed
1. 3Com the 5th UI refine.
2. Support 3 more DDNS secrecies.
3. Support ‘-‘and ‘,’ for virtual server.
2.8b8/ 2007/6/8
Bug Fixed
1. debug firmware to dump memory information.
2.8b7/ 2007/5/15
Bug Fixed
1. failed to connect to device after unplug cable.
2.8b6/ 2007/6/5
Bug Fixed
1. DMZ entry Patch.
2.8b5/ 2007/5/15
Bug Fixed
2.8b4/ 2007/4/30
Bug Fixed
1. Support special characters for PPP username and password.
2. Support WPA-PSK with special characters.
2.8b1/ 2007/4/13
Bug Fixed
1. Fix UDP block port configuration lost problem.
2. support flexible schedule rule.
2.8b/ 2007/3/30
Bug Fixed
1. Fixed IPoA setting cause “out of memory” problem.
2. Add reboot log for debugging purpose.
3. Modify version name format.
2.8a/ 2006/12/22
Modification
Upgrade dsl driver.
2.8/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Modify schedule rule.
2.7d/ 2006/12/22
Bug Fixed
1. 3Com GUI refines. Please refer to SG GUI review pt 3.xls.
2. Disabled SIP ALG at default.
2.7c/ 2006/11/22
Bug Fixed
1. DHCP assign range problem.
2. DHCP fixed IP assign issue.
3. DHCP lease table not line up problem.
4. Turn one DNS proxy if NAT disabled.
5. Modify telnet session welcome message (BCM 96348 ADSL router to 3Com ADSL router).
2.7b/ 2006/10/27
Modification
1. Change system objects ID to 1.3.6.1.4.1.43.19.16/17.
Bug Fixed
1. LAN subnet mask shows up invalid error if set the correct value.
2. DHCP IP range assignment did not check weather is on the same subnet or not.
2.7a/ 2006/10/20
Bug Fixed
1. UI pop up warning message about DHCP IP range assignment.
2. LLC and VC/MUX display error.
3. Add DNS server to PPPoE and PPPoA.
4. Instability issue.
5. Login error while type correct password and press enter.
6. Upgrade countdown seconds is missing.
7. PC in different subnet unable to connect SNMP.
8. Lose System log settings after reboot.
9. Directly open file while saving configuration or log will cause open empty file.
2.7/ 2006/10/05
Modification
1. UI modification according 3com’s request.
Bug Fixed
2. Fixed Matis bugs. (Refer to mantis bug system)
2.6/ 2006/9/26
Modification
2. UI modification according 3com’s request.
Bug Fixed
3. Fixed Alert light on system hang problem.
2.5/ 2006/9/8
Modification
2.4a/ 2006/8/28
Modification
Bug Fixed
1. Set NAT default setting to enable.
2. Display URL block message.
3. Modified settings to apply right away. (only partial settings, some of settings still need reboot)
4. Wizard does not “pop up” after upgrade or reset to factory defaults
5. “OfficeConnect” banner in blue does not cover entire width of page.
6. Fixed channel in worldwide version.
Posted on Nov 14, 2007
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
http://booobi.googlepages.com/uperJerry_V2.8b4_Worldwide_A.rar
Posted on Oct 24, 2007
2 Suggested Answers
  • 38 Answers
SOURCE: Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Posted on Feb 28, 2008
I need firmware for 3Com WL602
You can download the firmware from this WEB site.
http://webtopicture.com/download/download-3com-wl--firmware.html
Dec 11, 2012 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
I would Like To get a Firmware or driver of 3com router 3crwer101u-75.
swich on and of the small swich the phone wire check it call me if nothing works
407 729 7647 ask robert
Aug 12, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I forgot my admin password for Wirelles Router 3Com "Office Connect ADSL Wireless 11g Firewall Router" what i have to do ? i don't want to reset my Wireless Router couse that make's me have to reconfigure...
if you havnt changed the password to the router then it should either be "PASSWORD" "ADMIN" "ADMINASTRATOR" in the worst case senreio you may have to reset the router.
Apr 20, 2010 | 3Com OfficeConnect Wireless Router
I bought a 3com 3crwe554g72 and when it connect with my ADSL modem the speed will become very slow (-50%). I update to the lastest firmware but no help
3com used to be good things back in the old days. But this hardware is probably self destructing in some way (the problem is widespread, the manufacturer claims it is an old product and gives no solution). Do NOT buy network products from 3com (HP today). Correct me if I am wrong..
Aug 11, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
3Com® OfficeConnect Cable/Dsl Wireless router not responding
Unless, you can try another computer to connect or there is a tiny (and I mean sometimes pinhole) reset button to push, it may have seen its last day. It has happenned to me and I picked up a little 35 dollar Belkin that worked great.
Jul 06, 2009 | 3Com OfficeConnect Wireless Router
Automatic restart of the router
try checking ur modem button or reinstall windows .if problem presists then contact me at afzaalafridi@rocketmail.com
Apr 30, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Ugrade 3com router 3CRWDR200A-75
The first thing I would check would be in the configuration (point your web browser to 192.168.1.1 when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
Mar 24, 2009 | 3Com OfficeConnect Wireless Router
3Com OfficeConnect Wireless Router Logo
3,262 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
