Question about Neff B1721 Compact single Circotherm oven
Neff B1721 oven
I have bought a display moben kitchen with appliances. The oven (neff b1721) is electricaly wired in correctly. Everything works except the heating element. when it was wired in for demonstration could they have disconnected or changed the wiring inside so that everything works except getting hot?
I have looked inside, and all wires are connected, although i have no internal electrical diagrams for the oven so i dont know if anything has been changed.
Can you help me on this matter?
  • gladimold Jan 02, 2008
    Exactly the same problem.I purchased an ex demo model which had been made safe? I need diagram to bring back to working order.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
Display works ok, fan works ok, but no heat. Assume element has gone, can this be replaced from the inside the oven without removing unit from built in housing?
I've never worked with a Neff appliance before, but generally, a firm tug will remove the element and a replacement can be firmly pushed in and all systems are go after that. The built in does not have to be pulled out. I suggest you take a look at the owner's manual or call a repair shop in your area that services Neff. If they have the part, ask them if the element can be remove by simply pulling it out.
Nov 01, 2010 | Neff B1644 Electric Single Oven
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Neff B1721 Compact single Circotherm oven Logo
405 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
