Question about HP LaserJet 1020 Printer
Regarding printing of envelopes.
I have created my own envelope using ms-word, i have set all the margin and all other important setting which is required for printing the envelope. But whenever i insert envelope on my printer tray and give command to print, than almost left part of text is vanish in printing and whole matter (text & graphics etc) is shifted to left hand approx 2.5 inches. i have tried installing latest drivers, even i have changed my usb cord. but that too problem exist.
  • 3 more comments
  • Anonymous Nov 04, 2007
    When I try to print an envelope on the HP Laser Jet 1020 Printer in MS Word 2007 manual feed, I get the message "A program can't display a message on your desktop." I have downloaded the latest drivers from HP.
  • Anonymous Feb 13, 2008
    I have the same problem on my HP 1200. Part of the text is cut off of the envelope. Even if I delete and paste in the Delivery box it still cuts off part of the text on the envelope. I have installed the latest HP driver.
  • kchurch197 Jul 18, 2008
    Mine is a LaserJet 950 and has the same problem. We went to printer setup and it shows the custom envelope size but when it prints in will only print #10 even when you set the printer for custom size. Leaves too large a margin on the left side so that print runs off the envelope
  • iftikharsal Aug 24, 2008
    kindly tell me how to print addresses on the envelopes. Do I need to type the address separately or the info is taken from the letter . I tried to type the address separately but is gets printed every where except in the middle where it shoud be.
    I have a HP laser Jet 1020
    Dr> Iftikhar salahuddin
  • Anonymous Sep 03, 2008
    When I try to print an envelope on the HP Laser Jet 1020 Printer in MS Word 2007 it print my envelope after 3" blank space so my address is not print properly on envelope.
    Problem Solver:
  • 18 Answers
At first try the full A4 paper.if the print is ok then try to use the custom paper setting and the proper paper feeding,means either portrait or landscape.
Posted on Feb 20, 2008
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Posted on Dec 13, 2007
Envelope address is printing at the very top of the envelope, in the center. I've tried adjusting the spacing (# inches from top) in Word under envelopes, but the printing stays in the same spot!
experiment with this
open a new document and type in the address where it would be on an envelope
when you have it in the center of the document go to print and see where it is on the preview
now while in that area click on page margins and move the margins to around what you have on the preview
then set as default
that should mean that what ever is going to be printed will appear in that part of the page or in this case the envelope as the printer and program is set to margins and everything inside those margins will be in the right place
basically it is trial and error but what you want to do is in that section of printing
Mar 02, 2017 | The Office Equipment & Supplies
How do I print envelopes with my hp c6180
There are 2 things that need to be done. 1. You need to make sure your document is set up correctly.
If you use MS Word 2003, go to Tools, then Letters and Mailings, then Envelopes and Labels to create your envelope. For Word 2007/2010, http://www.dummies.com/how-to/content/how-to-print-envelopes-in-word-2007.html.
2. When you select print go to preferences. From there you will need to set the paper type to envelope. On the application side, you will typically need to make sure your document size is that of an envelope.
Feb 28, 2011 | Office Equipment & Supplies
Printing small envelopes
In Word 2007, use the Mailing > Envelopes > Options section.
In 2003 I think it was under Tools > Envelopes & Mailings > Options.
There you'll be able to specify if the manual feed is top first or edge first, to the left, centered, or to the right, and how far over and down to place the address and return address.
After a few adjustment runs, it works great.
Jun 09, 2009 | Dell 5110cn Laser Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Envelope printing
its possible you dont have the right margins set, so it is printing outside the borders of the envelope.
check also your printer drivers to make sure its set for envelope, and also, generally the envelope goes in at length, not the width.
thanks
Apr 02, 2009 | HP LaserJet 4000n Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printing Envelopes
Be sure you have set the PRNIT PREFFERENCES on your program that you are using to print the envelope to accept a #10 envelope and not 8.5x11 paper, you ALSO must set the PRINTER PREFERNECE to MANUAL FEED and not automatic so it won't look to the paper tray.
//CowboysFanZ
Mar 28, 2008 | Dell 3100cn Laser Printer
Printing envelopes
Try setting the page setup to 8.5x11 and adjust the margins to landscape, top and left margin approx 4". A lot of times the envelope templates are afterthoughts.
Pagemaker programmer's supervisor, "Forget that template, nobody will ever print envelopes in Pagemaker"
Hope this helps!
Mar 02, 2008 | HP Color LaserJet 2600n Printer
Printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Jan 25, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer
This would depend upon the software you wish to use. For instance MS Word has an envelope printing utility built in. Access it through TOOLS > LETTERS & MAILINGS > ENVELOPES & LABELS, use the HELP feature to read help info on the settings required. If you wish to use a simlple text editor like Word pad, simply set the PAGE SETUP settings to reflect the media you are using; for instancce set paper size to ENVELOPE C5, and then the margins to something like Left = 60 Right = 100 Top = 80 Bottom = 50 Click OK and this will then mean when you print your document the text will be kept toward the center of the envelope. Change the envelope and margins to whatever suits you best. Slip the envelope into the printer (face up and flap to the bottom) and push the guard up. You should be good to go.
Mar 27, 2007 | Epson Stylus Photo R220 InkJet Printer
HP LaserJet 1020 Printer Logo
1,028 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
