Question about D-Link Computers & Internet
Windows cannot locate the server copy of your roaming profile and is attempting to log you on with your local profile. Changes to the profile will not be copied to the server when you logoff. Possible causes of this error include network problems or insufficient security rights. If this problem persists, contact your network administrator. DETAIL - The network path was not found.
    Brigadier General:
  • 10,406 Answers
When you "logon" to your local network, your computer is configured to fetch your "desktop" (My Documents and wallpaper and everything else) from a "server" computer on your network.
Was your "logon" to the local "domain-server" a successful login?
Does your local Network Administrator indicate that the "domain-server" is functioning properly?
Does that server's log-file show any error-messages, such as "not allowed to login between 10 PM and 6 AM" (a "security" setting on the server).
Since your "desktop" could not be loaded from the domain-server,
your computer has used a "local" copy of your "desktop",
and it is warning you that any changes will *NOT* be "merged" back to your "network" profile.
Have you contacted you local Network Administrator? What did she say?
Posted on May 27, 2009
When i log in to my computer, i am been given a temporary profile,how can i return to my user profile
Windows has a roaming profiles if you are on a networked computer. Change it back to local if you have rights and not on a work PC. Right click My Computer > Properties > Advanced > User Profiles > Settings. Highlight the profile and Change Type.
Nov 01, 2012 | Advent Computers & Internet
When i try to log-on i put my pasword into the box and says "the user Profile Service service failed the log-on.User profile cannot be loaded. what do i do
To resolve this problem open yourself, follow these steps:
Right click Computer > Properties > Advanced system settings > Advanced tab > Under User Profiles, click Settings > In the User Profiles dialog box, select the profile that you want to delete > click Delete > Apply/OK.
Next open regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
Right-click the SID that you want to remove, and then click Delete.
Log on to the computer and create a new profile.
Alternatively, you can simply download and use this Fix It 50446 from Microsoft given on KB947215.
You may also want to check out ReProfiler. It is a freeware tool for manipulating user profiles on Windows 7, Vista, XP, 2000, Server 2003 & Server 2008.
OR
you can try with the following link
http://support.microsoft.com/kb/947215
Thanks
Sandeep
Mar 10, 2011 | Toshiba Satellite M305D Notebook
XP problem
It means your roaming profile in server is missing.
please tell me do you have roaming profile in domain or not.
May 03, 2010 | Microsoft Windows XP Home Edition
Roaming profile error when I log on with my hnah\3500018 id.
how to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Apr 15, 2010 | Profile 200SX Car Audio Amplifier
had similar problem w same router when originally purchaased call linksys theyll walk you through it there custmer support is xcellent and they speak english only takes a few minutes
May 25, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Network path not found as defined below when logging on
Sounds like you took your work computer home to do some work and its looking to connect to the company server to get your credentials to give you access to the system and files.
I would guess you need the VPN connection to connect to the server its looking for.
From what info you provided that's all we can tell you.
Aug 28, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Network Path not found
Your windows profile is broken,.or loaded from another computer (or server) that is down or not running. If you and your computer go direct to the net, not through some kind of network, then you might want to creat a new ADMINISTRATOR profile (via windows control panel)and delte the old one once you have copied what you need.
May 25, 2009 | Linksys Wireless-G WRT54GS Router...
Users are having trouble logging in. Can't load profiles. Server not available.
Have you recently renamed the server that stores roaming profiles for your users? Or worse yet, decommissioned it?
Apr 14, 2009 | Computers & Internet
Setting up Active Directory and login scripts based on PC's name
if you are using AD.
do the following:
open AD, select the user, right click on the user and select porperties.
click on the Profile tab, put in the location where you want the file to g to.
i.e.\\server\laptop1\mydocument.
you can alway created a roaming porfile and direct the home folder to the server.
Note:
this is only effective if the user login to the network. if not, then the document will be on the local machine.
Dec 04, 2008 | Microsoft Windows Server Standard 2003 for...
Tungsten E and Outlook 2003 sync problem
yes I moved my files to a new machine and reinstalled palm (which of course also created the dreaded multiple copies of many palm contacts, when palm discovered older archives, but that is another story!) I wouldn't mind that if the palm pilot would just sync with outlook 2003. It synched with Outlook 2000 on my old machine.
Sep 11, 2005 | Palm Tungsten E Handheld
Computers & Internet Logo
2,405 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
