Question about NEC MultiSync FE700 17" CRT Monitor
Operating at a slower than recommended refresh rate
My nec multisync fe700 is operating at a slower refresh rate than normal. how do i fix this problem?
  • 702 Answers
The refresh rate can be configured in Windows in the display properties. It does require that your monitor has been identified or configured, otherwise it can limit the refresh rate.
You can overrule the setting to not limit the refresh rate to compatible devices only, but be careful to not configure it too high as it can break your monitor!
Posted on May 25, 2009
Hi,please if you can help me.I have NEC MyltiSync FE 1250 monitor.It stoped working when is connected to desktop,it has light on but the screen is blank.I've connected it to laptop and it works fine but...
You have proved the monitor is OK.
If the desktop appears to boot up then the most likely problem could be a faulty video card OR the video card setting has been changed that is outside the range of the monitor's capabilities, ie, the refresh rate set too high (set it to 85Hz or less) or the screen resolution is set too high (set it to 1024x768).
You may need to connect a different monitor to the desktop to get a display to lower the video settings.
Sep 03, 2010 | NEC MultiSync FE700 17" CRT Monitor
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Jul 16, 2009 | NEC MultiSync FE700 17" CRT Monitor
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
Driver for NEC Multisync XE21
Normally if you set the refresh rate to match what the specs are (mentioed above), it should go you working.
Jun 07, 2008 | NEC MultiSync XE17 (White) 17 in.CRT...
FE700 with double line in the screen
as it is a trinitron tube, this two lines are there on each tube, it is nothing to worry about. it is like this, get used to it
Feb 04, 2008 | NEC MultiSync FE700 17" CRT Monitor
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
NEC MultiSync FE700 17" CRT Monitor Logo
619 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
