Question about Ace Hardware Ace& Battery Back-Up Sump Pump
Alarm says terminals corroded
It is only 5 months old and it constantly goes into alarm and says "terminals corroded or replace battery". The terminals are clean as a whistle and I can't believe the battery is bad. I press the reset button, it does a run cycle and the alarm resets but an hour later it is back in alarm. What gives ???
  • 323 Answers
One of two things:
Somewhere in the wiring you have a weak connection and it is interpreting it as a bad battery or corroded terminals. It could even be where the cord goes into the sump pump. You will have to search it completely to find it.
The alarm itself is bad.
Posted on May 27, 2009
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
When I replaced battery my MPT1340 alarm armed it will not disarm either by key or remote
by removing the battery it is possible to corrupt the CPU program where the alarm is located. Constant removing of the lead fixes it immediately but not the corrupted program. Try using a scanner to reset the program.
Nov 29, 2014 | Cars & Trucks
Disconected battery for 5mins now the alarm goes off when doors opened but engine still starts Toyota corolla 1998.
Reprogram your cars alarm,there are many ways depending on your alarm and car model
Oct 20, 2017 | 1998 Toyota Corolla
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
I am trying to replace the battery for a '97 Suzuki Sidekick. The battery terminals were so corroded, I had to cut the wire and put on some universal terminals. There are two wires for each terminal-
This happens in the shop all the time. It is not necessary to remove the alarm if you have the remote for the alarm. Simply hook the battery up and press the button to turn the alarm off.
Nov 23, 2011 | 1997 Suzuki Sidekick
My battery alarm keeps beeping. The system is less than 3 months old (Including battery) The battery terminals are not corroded at all. It is plugged in at all times. What can I try to fix this?
You really need instructions to understand this system. I know that on some units, there is a water level probe that alarms. Does the battery need distilled water?
Also in some cases, if the unit has operated because the main pump failed, it will alarm to let you know to fix the main pump. Push the reset button & hold it for 10 seconds to reset that alarm.
Do you have trouble lights & an explanation? If not on the battery, check your instructions.
Gary
Sep 19, 2011 | Ace Hardware Ace& Battery Back-Up Sump...
1997 Jette won't start , turn key on & alarm goes off
I had the same problem. Mine was a battery issue. Enough power was getting through to turn on the accessories, but not enough to turn the starter. When this happened, the alarm would go off. The positive and negative terminals were extremely corroded, which disrupted the connection. Clean the insides of the terminals with a wire brush and you should be ok. Also check the condition of the battery.
May 01, 2009 | 1997 Volkswagen Jetta
I have a honda accord 2000 and the alarm goes off alone
check the bonnet switch after awhile these get corroded and cause false alarms,just disconnact it for a week if your not sure,also check the alarm hasn;t suffered water damage and if the car has a motion .ultrasonics sensors the may be to sensitive arm the car wait 5 seconds and then kick a tyre it should;nt go of unless kicked quite hard.
Apr 12, 2009 | Vehicle Parts & Accessories
Ace Hardware Ace& Battery Back-Up Sump Pump Logo
301 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
