Question about Dell Inspiron 6400 Notebook
Laptop battery timing
My laptop dell inspiron 6400's battery timing has deteriorated. it now gives me almost 15 minutes of normal usage without the adapter connected to a power outlet. i need help, as i dont want to spend my pocket money on buying a new battery!!!! any suggestions on how to increase it????
  • Dell Master
  • 4,806 Answers
Hi there.
The battery is degrading so you have no choice but use it on AC power for the time being until you have saved up enough money for a new one, you will not be able to increase the charge.
Sorry to be the bearer of bad news but this is how the electronic world goes.
Good luck and thanks for using FixYa!!
Posted on May 25, 2009
  • Dell Master
  • 13,433 Answers
If you know how to work a soldering iron and you have tools like screwdrivers etc.
You could replace the rechargeable batteries inside the battery case. Note that you will need the right kind of batteries for it. depens alot of whats inside it.
Do it at your own risk, reseach online for how to guides.
I wont post you a guide just because if someone messes it up their going to blame me, so do your own research online and I think you might be able to get the battery good as new by replacing the batteries inside.
At your own risk, becarefull and don't take shortcuts, do it with care make sure you got the right parts etc before soldering them in place etc. read atleast 1-3 guides on the topic.
Posted on May 26, 2009
  • Dell Master
  • 3,866 Answers
Well your going to need to run this computer with ACPI and that means every 5 mins with no use the thing will go to sleep, otherwise grab deep into your pockets and get a battery
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400,replacement battery is not recognised when installed
The system may need up to 24 hours to charge the battery if it arrived in a totally discharged state. It may look like nothing is happening, but give it time.
Nov 24, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 Battery problem
what i would suggest is to check the bios there may be a new flash download on the dell website, my wife has a inspiron 1525, which is plugged in and says not charging, the battery will not go above 0%, but we have had to send it to dell (still under warranty) faulty motherboard. if the bios is up to date, there could be a hardware issue with the battery or motherboard
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Reduced Battery Working Time Problem
May be the battery life has been reduced due to overcharging so replacing the battery will solve the problem or try to run the laptop in minimal mode setings (display).
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400
How old is the battery? The battery is considered a consumable product. It really has to be replaced usually after a year or so. You may try updating your computer's bios software though to see if it will correct it. Updating this software is a bit risky and if not done correctly may further damage your system's motherboard.
Click this to see the instructions on how to run the update.
Click this to start the update. It can only be run though if the battery still has 30% charge. If you get an error during the update, you must replace the battery.
Nov 02, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
