Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Line red,yellow,green are all over picture and images
Last month I bought a
Wii and this month the tv is showing red, yello , green around the images and on the sides of the display. Is there a reset button that will fix this problem?
Thanks
BWoeppel
  • Philips Master
  • 8,617 Answers
No you will need to replace the Convergence Ics and possibly some of the 12 feed resistors. You can get the repair kit for your model at the following link which contains both cinvergence ICs and all 12 resistors plus free instructions with pictures so you can do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Posted on May 25, 2009
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
Bought new componant cables for new tv and the wii will not play in color. tryed moving cables around still no luck the different combo's that i tried either switched every thing to all red or all blue!...
Make sure the colors line up.
Red-Red
Green-Green
Blue-blue
If the tv has a second componant input then test it in that input.
What model tv are you pluging it into?
Did the wii work on the old cable?
Jan 03, 2011 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
    What to do will depend on how you're connecting your Wii console to your TV.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
I have a Samsung tv that has no place to plug in the yellow cord. It is a new high dollar HDTV what do I need to get the wii to play? No, there is no yellow hole, the picture is black and white, with...
The only way I was able to get around this was to plug into use component 1 then plug the yellow into the green on the far right. The problem I now have is that I can only use component 1. When I plug a dvd or wii into component 2, it shows still shows up in black & white, even when I plug the yellow into the green. I am not a happy Samsung owner.
Dec 25, 2009 | EA Sports Tiger Woods PGA Tour 08 for...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
139 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
