SOURCE: nokia 5800 music xpress display problem
Sounds like the connection from the phone and ur touch screen is loose. Would suggest getting a technician to fix it. There are online resources that also show you how to do it.
SOURCE: nokia 5800 xpress music, i got it off a friend and
try a soft reset this will unblock it and set it back to factory without deleting your data .
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
SOURCE: phone startup failed contact the retailer?
hi you should get your mobile flash at your retailer's as trying to doing this by your own may damage the phone ;)
SOURCE: nokia 5530 xpress music phone start up failed
There can be a short circuit or any criticle problem therefore protective circuit in ur phone are activated & they stops phone to ON for avoiding the harm to u & ur mobile. It is appropriate to contact ur retailer or service center
SOURCE: hi, my nokia xpress music 5800 phone is blocked by
Call your sim service provider's customer care center, they will give you the PUK code instantly.
Please rate the answer. Thanks for using FixYa.
