Question about Whirlpool GGQ8831L Gas Dryer
Where is the coil valve located?
I have a whirlpool estate dryer that is not drying clothes. The last time this happened, it was a bad coil valve. I'm going to try to replace it myself and have seen pictures of what the coil valve looks like, but I don't know where it's located. Thanks!
  • 6,784 Answers
The coils on this unit are located on the gas/burner valve Assembly. this is a all in one situation. everything is located on the gas valve assembly. you will need to remove the coils from the gas valve assembly.they are attached to the valve assembly.
Located on the back side of the unit on the lower back side. (right)
Posted on May 25, 2009
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Jul 31, 2009 | Whirlpool Dryers
Whirlpool Estate Dryer TGDS840JQ1 dryer runs but does not heat up to dry the clothes.
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Jun 08, 2009 | Whirlpool Dryers
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
I have a estate electric dryer with no heat.
check the heater coil and limit switches....if either are bad you wont get any heat
Dec 25, 2008 | Estate TEDS840JQ Electric Dryer
We have an Estate Whirlpool clothes dryer/Model #MY60-G which was purchased (I think sometime in 2002?). It spins, but after it is on for a little while the heat stops and the clothes never dry. We were...
gas dryer ? replace the 2 coils on gas burner the 2 black round dohickys..electric possible bad operating thermostat remove back round object on blower housing
Jul 08, 2008 | Whirlpool Dryers
Whirlpool GGQ8831L Gas Dryer Logo
299 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
