Question about Maytag Atlantis MDE7400AY Electric Dryer
Igniter works fine but there is no flame so therefore no heat
My Maytag gas dryer model# LDG9801AAW does not heat up. The igniter works fine but there is no flame. what could be the problem?
  • 6,784 Answers
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
Posted on May 25, 2009
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
MAYTAG GAS DRYER MODEL SDG305DAWW. THE IGNIGHTER GLOWS BUT DO NOT REVEIVE A FLAME
Your igniter is working fine. The problem is the flame sensor needs to be replaced. The flame sensor is a safety feature. If it doesn't detect heat from the igniter it prevents the gas from flowing. A new flame sensor will cost about 30 - 35 dollars. You can buy on online here
Jun 23, 2010 | Dryers
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
Neptune dryer proble. The dryer works except no heat. Flame starts, but then turns off. Igniter element was checked and is good. What else should I check in order of probability? - flame sensor? -...
Hi
Thanks for using FixYa. Things that could stop an electric dryer from heating: - house fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
229 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
