Question about Toshiba 62HM95 62" HDTV
Color wheel making load noise.
I get a load srceehing niose when the tv is on some distrotion and some times the picture go's out. i was told the color wheel is making the noise. i re place the balest and lamp alreddy but i still get this srceehing form time to time
  • Toshiba Master
  • 8,617 Answers
Sounds like the bearings in the color wheel are failing.
Posted on May 25, 2009
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
After watching tv for a while I loose the color??
This tv have a colors wheel.The colors wheel effects is dying or dead are make loud squiling noises,motors noises and loose colors and flashes or flashes black&white with the picture.The colors wheel,must be replaced to solved this problems.The colors wheel is pretty hard to replace,because u require take many machanical parts out.Before u can even replaced the colors wheel itself.So hire the tv Tech. to replaced the colors wheel.
Nov 24, 2010 | Samsung DLP HL-P5663W 56" TV
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
I have a samsung hln5065wx/axx it has a black and white pitcher some times it will freez up a look like a xray pitcher
This tv have a colors wheel,it dead.Make loud motor noises,high pitch squiling noises,have pictures flashes black&white with the pictures.All these are the causes of the colors wheel.The colors wheel is dying and dead is spinning off of it motor axis.The colors wheel,must be replaced.Hire a tv Tech. to do the job.Because it not easy to replaced the colors wheel,u must take out alots of machanical parts even can come to the colors wheel to replaced the colors wheel it self.
Oct 23, 2010 | Samsung HLN5065W 50" Rear Projection...
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung DLP 50 inch tv, model #HLP5063wx xaa. A friend gave me the tv, and told me it wasn't working, probably needed a new lamp. When I try to power on the tv, it comes on but makes a terrible...
the lamp led will light when the color wheel is defective. If the noise you hear is a buzzing or screeching the color wheel is the most likely cause.
Sep 10, 2009 | Televison & Video
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Toshiba 62HM95 62" HDTV Logo
422 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
