Question about Honeywell Programmable Thermostat Heater
Sprayed windex on touchpad
Sprayed windex on the touch screen, now no buttons will work
  • 3 Answers
How about taking the cover off (if possible) and getting some compressed air, either from the can available at most computer-type stores or from a compressor with air gun attachment, and blow it out thoroughly as best you can.You may also want to 'rinse' it with some electronic cleaner but make sure you disconnect it to do this. You need to get the circuit board dried out and hopefully there is no other damage (ie. to the electronics).
No guarantees on this but it is the kind of thing I would do before having to replace it.
Posted on May 27, 2009
Gateway NV53A 15.6 inch Notebook, touch pad not working
Touchpad settings: right click on the touchpad icon on the Taskbar at the bottom right of the screen. Click on Default button, then Apply, then OK. Re-try. If that doesn't fix, then TouchPad ribbon inside the laptop needs to be replaced.
Feb 09, 2014 | Gateway MT3705 Notebook
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Emachine E725 touchpad does not work
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
My lg vx110000 touch screen stopped working after i sprayed windex on a cloth and cleaned the touch screen.
i did this twice with my chocolate touch and mine also stopped working /: the prollem is you had a scratch in your phone, or it got into one of the cracks, and jacked things up in there.i wouldnt do that anymore :|
Apr 11, 2010 | LG enV Touch VX11000 Cell Phone
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
GPS touch screen sprayed with Windex; doesn't work.
After reading sharcnet's reply yesterday that putting the unit in the freezer was absolutely the wrong solution, I was very panicked! However, once the unit thawed out it worked fine. We tried the freezer because we've used that tip before to "freeze-dry" cell phones that got wet. Luckily the LCD was not damaged & everything is working fine now. And my husband knows not to spray Windex on any electronic screen!
Jun 01, 2009 | Garmin nuvi 255W GPS Receiver
I sprayed windex on my ps2 slim lens how do i fix it
Try carefully cleaning the lens with Isopropyl alcohol on a Q-tip. Any film left behind from the "Windex" may have caused distortion, or refraction of the lazer. Worst case scenario is that you may have been too vigorous cleaning the lens, and it may be out of alignment now.
Feb 11, 2009 | Sony PlayStation 2 (PS2) Console
LG LMVM1935SW Microwave
Actually, that's a VFD display, not an LCD type, so the burn mark is normal. That mark is created when the tube is evacuated.
You wouldn't need to take apart the door just to replace the keypad.
That's something we do for $39.95 but if you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Zen Touch 40GB Scroll Problem.
There is a circuit board under the touchpad that has probably gone bad. You should purchase a Zen Touch with some other problem like bad hard drive or broken screen, but that has a working touchpad, and swap the outer body for the working one.
Sep 11, 2007 | Creative Labs Zen Touch MP3 Player
Heating & Cooling Logo
263 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
