Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Fuel injectors location for a 1995 chevy camaro
Where are the fuel injectors for a 1995 chevy camaro located?
  • 3 Answers
That year uses a throttle body injector, which is located underneath the air cleaner. take the cover off and then take the housing for the air filter off. its right there
Posted on Jun 19, 2009
Where is the crank position sensor on my 1995 chevy camaro 3.4L
You didn't state which one you were looking for, so here's location of both. The 3X (low resolution) crank sensor is on right side of cylinder block forward of starter solenoid----The 24X (high resolution) crank sensor is at crankshaft pulley.
Oct 02, 2014 | 1995 Chevrolet Camaro
Location of egr valve on 2003 chevy silverado
Hi there:
Here is a picture showing the EGR valve on the 4.8 Litre V8. The numbers below go with the picture. The arrow points to the front of the truck.
(1) Fuel Injector 2 Connector
(2) Throttle Actuator Control (TAC) Motor Connector
(3) Throttle Actuator Control (TAC) Motor
(4) Exhaust Gas Recirculation (EGR) Valve Connector
(5) Exhaust Gas Recirculation (EGR) Valve
(6) Fuel Injector 6
(7) Ignition Coil 2
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 14, 2012 | 1989 Chevrolet Camaro
Cant locate my fuel injector in my 95 chevy blazer
Your '95 blazer does not have fuel injectors as such. Fuel delivery is accomplished by way of a " throttlebody" injection system. This unit is mistaken for a carbuerator but is systematically controlled through several electrical connections by the on board computer.
Apr 10, 2011 | 1995 Chevrolet Blazer
Where is the fuel pump on 84 camaro
if this car has a carburator it located on the front of the engine pass side! if its a tune port its in the tank
Apr 09, 2010 | 1984 Chevrolet Camaro
Where is my fuel pump at? on a 1995 chevy camero 3.4 yes ran the car out of gas put so in wont start now what should i do first
Your fuel pump is in the tank. Turn on the ignition, and listen if you can hear the pump run in the tank. It will only run a few seconds if the engine is not running. You can repeat this several times to prime the fuel injection.
Feb 11, 2010 | 1995 Chevrolet Camaro
How to change the fuel injector seals on a chevy camero 1995
The injectors should be connected to the fuel rail, which looks like a long shiny tube, about the size of a sharpie marker. remove any bolts securing it to the in-take manifold. Then carefully lift the fuel rail off the top of the engine and u should be able to see all of the injectors.
Oct 14, 2009 | 1995 Chevrolet Camaro
Locating the Fuel filter
the fuel filter is located under the car in fuel line just before the fuel tank
Oct 04, 2008 | 1983 Chevrolet Camaro
1995 fuel pump relay
located under the left kick panle.
Oct 02, 2008 | 1995 Chevrolet Camaro
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
227 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
