Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Yellow light blink when powered up
Dell pc 5150 blinks yellow when powered up
    Sergeant:
    Champion:
  • 212 Answers
That is the hard drive. does it work? If it does I wouldn't worry about it.
Posted on May 25, 2009
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Yellow light on power button keeps blinking but doesn't boot.
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Mar 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Blinking yellow power led
check at the back of the tower you would find 4 LEDs(small lights) labeled ABCD in a row or you might have 1234 on the front panel. note the status of these LEDs when the problem occurs and check for the solution accordingly on the support.dell. website.
would also suggest to disconnect all the devices (keyboard mouse printers etc.)next time the problem occurs and then try to start the computer
May 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
