Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Wiring for an Amana PTL
I am in the maintenance Dept. of a small hotel in Memphis. We have numerous Amana PTL models. some of the rooms here are wired with straight 240 volts on one leg with a ground. Other rooms are wired with 220 using 2 110 legs and a ground. Will the Amana's work either way and if so do they require a change inside the unit to do so?
Thanks,
Hayden
I have an 2003 Amana ptac unit. The control board burnt out. I had the board replaced, the old board was analog the new one is digital. Since changing the board i set the temperature at 72. I have a thermometer in the room and the temp. won't go below 80 degrees. I never had this problem before the board was changed. Can you help me with this concern. Thanks
Posted on Jun 09, 2009
    Guru:
  • 1,524 Answers
That is a stinger leg and you will burn the unit up. 2-@110/ground is what you need.
Posted on May 25, 2009
Yes ovetime it will burn it, I think you have delta type wiring at your hotel one of the old style, check with electician to find you have delta or not and they will fix it, so every room you get 220 using 2 110 legs.
Posted on May 27, 2009
Memphis 1500d amp
The flashing indicates that the amplifier is in 'protect' mode, which is often a sign of a ground fault, but may also indicate that one or more of your power and/or signal wires is crossed, connected incorrectly, or shorting out for some other reason.
In short: Go through all your wiring and check it thoroughly. Be patient, take your time, and I can almost guarantee you'll find the problem in a loose wire or perhaps your ground wire isn't connected to a part of the chassis that is fully grounded.
Unfortunately the Memphis 1500D is a discontinued model, so installation instructions for it are not readily available... however, the SPL 1500D is a very similar product and the wiring should be identical, so for your reference here is the installation manual for that unit:
http://www.spldynamics.fi/products/amplifiers/ICE-series/splclassDmanual1220.pdf
Hope that helps, good luck!
Dec 03, 2013 | Car Audio & Video
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Wireless in hotels.
Most hotels provide a service using different providers. Check with the hotel your staying at. It will work in the US and Canada.
Jul 27, 2008 | Computers & Internet
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
365 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
