Question about Filter Queen Majestic Canister Vacuum
Majestic filter queen vacuum
Wand is broken and the beater head stopped working this morning. Suction gets to the beater head. Pushed the little red button but it did not help this time. Is the wand part of the lifetime guarnatee?
SOURCE: majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
Posted on May 25, 2007
SOURCE: need manuel
I've found an online manual in pdf format
Posted on Apr 22, 2008
SOURCE: Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
Posted on Dec 02, 2008
DAZ4161
  • 7 Answers
SOURCE: vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Posted on Dec 13, 2008
  • 83 Answers
SOURCE: Decreased wand suction
The blockage could be in the wand itself or in the entry duct of the machine. Take the wand off, look through it and if you can't see light coming through the other end, there is something stuck in the wand - take it out with a long object like a metal hanger...if the wand is clear, call the Dyson helpline - they will do a thorough blockage troubleshoot over the phone and clear the blockage.
Posted on Jul 30, 2009
There is no power to my Filter Queen power nozzle. I have cleaned the connection and there is still nothing.
There is an electrical connection at the canister end and again at the beater end. If the beater is not working it is mostly that this is where you problem is. You need to test first to see if there is power at the canister end and then at the beater end. If there is no power at the canister it could be the outlet or something internal. If there is no power at the beater end then that outlet, or the cord could be the problem. If you have power and that end then the problem is likely within the wiring in the beater or in the motor itself
Jan 20, 2015 | Filter Queen Majestic Canister Vacuum
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
What if my filter queen carpet attachment does not turn on
Probably the plug in connector between the hose and wand or wand and head... check them for obvious arcing or looseness, visually or by wiggling the connection. If you find the faulty connection, you may find the cord with faulty end on ebay or verizon. If the cord is incorporated in the hose or the wand, you may also nd them on the same two sources... Filter Queen will charge you too much...
May 19, 2014 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
The beater assembly on our Majestic 360 is not working. We've pressed the reset button, checked the belt, made sure the connections were complete. Suction is reaching the unit. What's our next step? Thank...
Check the power cord going to the unit with a volt/ohm meter. The wires break, UNPLUG and take plyers and slightly squeeze the female connections, and plug in again.
Oct 07, 2010 | Filter Queen Majestic Canister Vacuum
Getting power to attatchment?
There has been a recall on the hose, wand, and power nozzle. Mine just caught fire! Burned a whole in my carpet. I'd contact their customer service department and find out if yours is on the recall list.
Dec 30, 2009 | Filter Queen Majestic Canister Vacuum
There is power but the motor seems to not turn, therefore, there is no movement via the rollers. please help
The belt which turns the roller brush is probably worn and therefore not turning the roller brush. You can get a replacement here:
Filter Queen Majestic Replacement Belt
Nov 05, 2009 | Filter Queen Majestic Canister Vacuum
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Repair Service Essex United Kingdom
when you mean overhaul is the motor not working or are you experiencing loss of suction or wha seems to be the problem?
Nov 09, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
97 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
