Question about GE Profile JTP56 Electric Double Oven
GE JTP56 Double Oven
Wife did a self clean on lower oven.  Self-Clean went through fine.  Now oven won't heat up.  Temp sensor is around 1.080K at room temp and resistance increases when sensor is heated up.  Relay kicks on when start is pushed.  Elements?
  • sotto1 Apr 23, 2008
    We have a problem with the Top Oven not heating. We are not getting an error code. The last time it was used was on Broil. Display is still working on top, but no heating for Oven, Conv. Oven, Cleaning or Broil. The Bottom Oven is working fine. All we've done thus far is to turn off the power at circuit breaker, then retry but no luck.
To Powerman
I followed your instructions on fixing the "F7" error you posted on Jun 19, 2007. It worked like a charm. Thanks.
Posted on Apr 20, 2008
  • 68 Answers
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Posted on Oct 21, 2007
BOTTOM DOOR WONT LOCK FOR SELF CLEANING. The motor is making a noise but lever doesn't move
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
Oct 21, 2010 | GE Profile JTP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
Self clean
You should have detailed instructions in your owner's manual. Make sure you are moving the door latch (if equipped) from left to right to lock the door.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
470 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
