Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Fisher & Paykel dishwasher model dd602 error code F4
Need Temperature sensor and service manual.
  • 3,230 Answers
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • kymp10 Jan 16, 2014
    It is not dirty! i clean it weekly and had cleaned it the same morning this issue arose
Fisher & Paykel dishwasher. Why is it displaying fault F4?
According to the owners manual that fault code is for a faulty temperature sensor or element. It also says to contact an Authorized Service Center. Hope this helps!
May 15, 2015 | Fisher Dishwashers
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jul 14, 2010 | Fisher and Paykel Ovens
F4 error fisher & paykel nautilus dishwasher sometimes this error comes up and it seems to occur about 10 minutes from the end of the cycle. it doesn't happen all the time. the user guide does not...
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Mar 08, 2010 | Fisher Dishwashers
Help with and f4 fault code on a fisher and paykel disher
Without the model number I have to guess.
Fault code 'f4' means "faulty temperature sensor or element".
Here is a link to User manuals:
http://fisherpaykelparts.net/index.php?blockitemid=29
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Fisher Dishwashers
Fisher and paykel dd602 dishwasher manual
i have a dd602 codeind u 3 i need sevice manual
Nov 30, 2008 | Dishwashers
What is F4 error on fisher paykel dishwasher?
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher & Paykel DD602 Dishdrawer: F4 code
an element fault (disconected or faulty controller)
Aug 01, 2008 | Dishwashers
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
1,788 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
