Question about Garden
Clutch on tb70ss is slipping. how do I remove the clutch drum?
Clutch is slipping. How do you remove the clutch drum?
5 Suggested Answers
  • 279 Answers
SOURCE: tb70ss
If it is like most of the others, if you have the drum exposed, just take a #15 Torx screwdriver into the opening the shaft goes into and unscrew it. That will allow access to the clutch...Good luck...Lee
Posted on Sep 10, 2009
  • 430 Answers
SOURCE: LX176 Electric Clutch Slips
The clutch is basically a big 12volt elecrto magnet. When it gets power it grabs the magnet and turns the blades. Usually they either work or they dont.
I would check the relay first. Then check for a loose wire or bad connection.
If it comes down to a failed clutch then be prepared to spend between 150 and 300 bucks. remove the deck and unplug the 2 wire connector from the clutch then remove the center bolt from the crankshaft and the clutch will slide off the end of the shaft. There will be a bracket or pin that holds the clutch and prevents it from spinning. Pay attention to how the bracket or pin is situated and be sure to reinstall the new clutch the same way.
Posted on Jan 04, 2010
rycgl
  • 1545 Answers
SOURCE: Replacing pull cord --After clutch drum
This is the clutch. It is threaded onto the crankshaft (r/hand threads)..get a smaller size flat head chisel and a mediium size hammer and give a few good whacks on the raised solid part near the middle of the clutch...not near the springs nor on the outer edges. This should loosen it and it will unscrew right off the crank..If it's stubborn, spray penetrating oil (Liquid Wrench or PB Blaster) on it and let it soak overnight. Hope this helps you.
Posted on Jul 20, 2010
SOURCE: how do you remove the clutch drum assembly for model #316.791890
rycgl gave a great solution for removing the clutch drum, but after the clutch drum is removed, you have to remove the clutch itself from the shaft. It's threaded on, and there's an arrow on the clutch assembly that tells you which way to turn it to remove it (CCW). Once that is removed, you can take the casing off the motor, remove a cover plate, and get to the incredi-pull assembly. Mine went south, to, and it was because the incredi-pull loops the cord around two plastic rollers that rotate around plastic shafts. Of course plastic doesn't hold up very well, so over time, one of the rollers stopped rotating, and the cord cut a slot in the roller and its supporting shaft, which in turn bound up the cord so it wouldn't retract. Fortunately, I caught it before it cut all the way through the shaft, and I replaced the roller with a short piece of 3/8'copper tubing. It works OK, but I'm not holding out too much hope for it to last a long time. Hope this helps.
Posted on Aug 28, 2010
Replace pull cord
Replacing a pull cord is not easy. After you remove the shaft, then the drum cover, you are left with the drum and clutch. There is a screw in the center of the drum which has to come off. Then there is a the clutch which if not removed correctly will come apart on you. Only after both parts are remove can you get to the pull cord.
Oct 19, 2013 | Troy Bilt Tb70ss Gas Trimmer
Rope will not recoil complety
Pull cord broke for tb70ss
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Mar 23, 2011 | Troy Bilt Tb70ss Gas Trimmer
Prosedure on how to fix if the uper flex rod goes out it does not spin when motor running
The problem with your upper drive shaft may be clutch related. Here is how to get to the clutch to inspect it and the clutch drum that drives the flexible drive shaft.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next.It should have some play in it, but not a lot. See if it spins freely. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. If you get the drum off, inspect the clutch. The clutch pads should be uniform with no nicks, cuts or scorch marks. Check the plastic housing on the tube. It should not have score marks either. Next, if needed, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face, Use some lithium based grease to lubricate the upper and lower flexible drive shafts. Post back if needed.
Oct 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
Replace pull cord on troy-bilt tb70ss
Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Oct 02, 2010 | Troy Bilt Tb70ss Gas Trimmer
My TB70SS cranks and runs perfect! The problem is the clutch seems to not engage. The head will spin at idle speed, but, when I pull the throttle trigger, it seems to bog a bit, and the head almost quits...
There may be an issue with the clutch or the clutch drum. Some disassembly may be required if the string head doesn't spin quickly when accelerating the engine. The clutch itself is threaded onto the crankshaft of the engine near the handle end and the clutch drum is screwed into the end of the crankshaft. If you can disassemble to that point, you will be able to diagnose your clutch problem...maybe it is worn severely and needs replacing.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you take the clutch assembly off to get to the starter rope?
Thereis a T-10 or T-15 Torx Head screw in the recess at the end of the crankshaft. Loosen it (it may stay in the end of the drum) and drum will come off. Clutch is threaded onto crankshaft. Loosen it counterclockwise, but carefully. Rap the inside part near the crank with like a flatpblade chisel. Spraying the center with penetrating oil beforehand may assist in this step. Use Liquid Wrench or PB Blaster. vDon't strike the outer shoes of the clutch!
Aug 12, 2010 | Troy Bilt Tb70ss Gas Trimmer
Tb70ss
Sep 10, 2009 | Troy Bilt Tb70ss Gas Trimmer
Washing machine will not spin dry but washes properly
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Nov 28, 2008 | Maytag SAV365ZAWW 3.3 cu.ft.
Garden Logo
315 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
