Cat Enclosure Frame
SOURCE: Changingthe ice enclosure
Hello, Msalloum:
I have the same Maytag refrigerator that you have and I faced the same problem with the ice enclosure. I have now replaced it. As to the problem of separating the yoke from the motor, you'll have to turn the yoke clockwise in order to liberate it. In my case, after holding the motor shaft with a pair of pliers, I had to tap the yoke with a hammer once or twice on a clockwise direction before the yoke became free.
In view that more than 2 months have elapsed since you posted the question, you probably have solved the problem long time ago. If you haven't, I hope you find this tip helpful.
lopezfra
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
SOURCE: I need to know the enclosure specs for the PSW615
Hello chetdyal,
For a ported enclosure with room for a port, you're going to need a box with about 3.0 CuFt internal volume. Using 3/4" material and outside dimensions, this translates into a box 25"(w)X18"(h)X15"(d) giving you 3.03 CuFt allowing a little volume for the sub and port displacement. For a tuned frequency of 38Hz, you'll need a rectangular port 2"X6" and 4.6" in length. A round or cylindrical port for the same tuning frequency would be 4" in diameter and 4.9" in length. Increasing the port length will lower the tuned frequency.
There's excellent volume and port calculators on The12v.com web site. I'd recommend that you browse some of the "box-building" information before you begin your build. The DIY Subwoofer site also has some great resources.
Keep in mind that a ported enclosure will tend to produce the loudest bass notes very close to the tuned frequency. So tune it higher or lower according to the music you will be playing.
Hope this helps.
SOURCE: need help im planning to build a enclosure for my
Hello marne_glenn,
Here's a link to Lightning Audio's manual for the S3.10.4.
The minimum recommended size for a sealed enclosure is .5 CuFt. There is no recommendation for ported.
Hope this helps.
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
