Question about KitchenAid Microwave Ovens
DOOR ERROR ON DISPLAY - KitchenAid Microwave Ovens
  • 6,784 Answers
Hi, simply replace the door latch mechanism on this microwave. this is a quick fix for this issue.
Posted on May 25, 2009
We have a may tag convection oven tat is displaying error code F5E2
This is a door lock error code. The same error code is also used on top loader laundry washers.
Whirlpool Fault Codes
Oct 04, 2016 | Microwave Ovens
DeDietrich oven - "door open" display will not switch off even with door closed - therefore will not advance to the choosen programme
The door switch is adjustable. Getting to it involves taking the cover off to get to access the switch. If adjusting won't solve the error, then a replacement is in order.
Mar 17, 2016 | Microwave Ovens
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
What does error message F5 mean?
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
I'm not finding the one for for this model online.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
More info on switches is here.
One of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
If it's not a convection model, F5 is probably a sensor error.
On some models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Here's some info from Samsung, which is the actual manufacturer of these ovens:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Feel free to contact me directly if you need more help.
Aug 22, 2010 | Frigidaire GLMV168K Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Displays F6 error code, hums when you start it and the tray circulates when you open the door
Depending upon which make and model you have, F6 is the code for either relay failure or shorted tempurature probe.
May 01, 2009 | Microwave Ovens
My microwave oven is displaying sensor error
Nov 19, 2008 | GE JE620 Microwave Oven
I have a GE sensor miceowave oven, Bought June 22 2008 When I try to warm anything I get sensor error. I have tried all the things in the owners manual. Can you give me any help? J M...
Did you see and try all this?
If you did, and you still get the error, your sensor may have failed.
I would suggest you contact GE Customer Service here.
This would be under warranty.
Oct 21, 2008 | GE Microwave Ovens
GE microwave model jes1456 has sensor error
Aug 23, 2008 | GE Microwave Ovens
Microwave Ovens Logo
208 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
