try soaking in hot water should loosen liquid soap,try pumping it every so often.try soaking in hot water should loosen liquid soap,try pumping it every so often.
You can't post conmments that contain an email address.
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer. I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
Try removing the **** Trap under the sink, there are two nuts one on each side. put a pan under the sink to catch the waste water in the trap first. ext loosen the nuts with a pair of channel locks or a pipe wrench turn the nuts counter clock wise direction till the nuts are loose slide the trap down and empty the contents of the trap into the bucket. Use rubber gloves so you don't get sick from germs. If the **** trap is plugged use a coat hanger to push threw the trap to get whatever is plugging it out. Rinse in a different sink, If it has the rubber gaskets I would recommend replacing the gaskets. Install in reverse. Do not over tighten the nuts or you will have to replace the parts. the trap looks like 2 opposing J .
Hello. You will find that the bottle will come out once you remove the nut under the surface of the sink. You have to get into the cabinet to do this. And, a faucet wrench, available at any hardware store will assist you greatly. Regards, joe
About the soap: You can use both. I prefer tablets.
About the particles: Before putting the dishes in, remove the food with a brush ($2.00) in the sink and run the hot water from the faucet for a 1-2 min until it gets really hot.
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
