Question about Dell Dimension 3000 PC Desktop
Dell dimension 3000 + maxtor hard drive. comp wont start
When i plug in maxtor hard drive which worked fine prior to moving... it will not let windows start.. device manager says ''cannot start code 10...... yellow asterik by usb mass storage device... i need to know what i can do to retrieve info off hard drive sinc ei cannot get it to start with windows.. plug n play drive no drivers to install etc.. can i check partitions or reset the factory setting on computer? or default bios settings.. i was in the bio and partition screen one day but i do not think i changed anything looking at it but may have?? if someone could email me id appreciate it i got valuable items i need to acess on the HD foreman1172@mchsi.com thank you
    Scholar:
  • 70 Answers
Well if you are sure you have not tampered with the HD during the partition section then there is a way out.
The yellow sign you saw on the device manager indicates that the driver is not compactible and hence the device would not be operational.
To get the vital data off your HD, get a good working HD and attach it to your PC as the master and enable the HD you want data from as the Slave.
This will make your computer boot from the Master and when its up, you would have access to the slave which is the HD you want access to and get the data from Windows Explorer
Posted on May 25, 2009
  • 111 Answers
Try the following to see if it's helpful:
1) Turn the computer on
2) Press F2 to enter the BIOS ( a grey screen should come up)
3) Turn on caps lock,scroll lock and num lock on your keybord
4) Press Alt +E then Alt +F then Alt +B
If that doesn't work you can pull the CMOS battery to clear the BIOS. It is on the board and resembles a watch battery. You have to pull it for no less than 15 minutes to clear the BIOS.
Hi just installed Windows XP Pro on a Dell Dimension 3000 with 1 gig RAM. This machine was running W2000 pro with no problems. But after formatting the drive and installing Windows XP pro and all updates...
Well you definately tried everything I would have sudgested.
It sounds like the Hard drive is near the end of its life.
If you have only just installed windows, it may be worth getting a new drive, installing your OS on that, you could then use the other drive as extra storage.
I have had a few HD that started to fail. Maybe the format and installation pushed it over the edge. You could always run maxtors drive check tool to see if it can detect a problem.( maxtor is now seagate)
http://www.seagate.com/www/en-us/support/downloads/seatools
Aug 06, 2010 | Maxtor Hard Drive
I recently moved and when i went to start up my computer it takes me to a blue screen say memory is being dumped. Prior to that though there is a screen saying that a "0 drive" can not be found. Any idea...
Your 0 Drive is the main hard disk drive in your computer. That is where Windows is installed. If the pc doesn't see it, it cannot start. If you've moved, the hard drive cable or power connection may have come loose. You can try opening the case and reseating all connections and see if that works. If not, it's possible your hard drive is damaged and not working.
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
We are planning to use our Dell Dimension 3000 for security alone. A friend told us to get a terabyte hard drive to support the software and video recording. What type do we need to interface with our pc.
Any brand name external USB drive should be good. Just a suggestion...Staples has a Seagate 1TB drive for $69.99 this Friday from 6 - 10 AM. That is a good deal.
Seagate, Maxtor, or Western Digital all are reputable companies.
Hope this helps.
Thanks for using Fixya.
Nov 26, 2009 | Dell Dimension 3000® Pentium® 4...
My dell dimension 3000 goes to blank screen after it shows windows xp logo and seems to stop there, how do I fix this?
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
Oct 01, 2009 | Dell Dimension 3000 PC Desktop
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell 3000
can you start it in safe mode?
Nov 16, 2007 | Dell Dimension 3000® Pentium® 4...
Cannot boot my dell dimension 3000
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
