Question about Broksonic TV
Turns off by itself and wont come back on
It will work fine for days and then mysteriously turn off by itself. i just pushed buttons and it came on but, i dont know what i did. now i cant get it to come on again
Sudden rainbow vertical lines, Loud squeel. wont turn off. Whats wrong?!
good first shut off the outlet for what is looking like this with your tv connection problems with the drain tube of images giving us the inside source for capacitors in a technical lead for the electronic exchange of capacitors and diodes for your device
Sep 06, 2012 | Samsung LN46A500 46 in. TV
Nokia 2220 wont turn on
This situation in phone servicing called Dead;there are many reasons for being so.You have to try sometips here-1-Take off batteryand clean the node with brush then put it back and press power button.
Nov 20, 2011 | Nokia 2220 Cell Phone
The laptop was working fine earlier in the day; I sat down at it and the power button was flashing. I ran my hand across the mouse pad to wake it up and it would not come on, so I pushed the power button...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | HEWLETT-PACKARD G72260US Notebook
Blaupunkt sevilla rmd168 turns itself off and wont come
Have you disconnected your battery or any fuses recently as it looks as though it requires a code to be entered.
May 11, 2010 | Blaupunkt Sevilla MP36 CD Player
Couldnt turn offn now cant turn on
just wait for the power to go off..it should be empty within the day or so...then check back on it...try turning it on...if u see a note saying it needs recharging then ull be fine
Feb 19, 2009 | SanDisk Sansa e250 MP3 Player
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
F7 SHOWS UP ON THE SCREEN
this problem just occured to me last nite. we had to shut the power off at the breaker box. we turned it back on this morning and it seems to be working fine. it is still a mystery as to what occured but it appears it had to reset itself. not sure if this is a solution, but it has appeared to be working so far.
Nov 23, 2006 | Kenmore 33464 / 33465 / 33469 Gas Single...
Broksonic TV Logo
67 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
