Question about Garden
I have a John Deere 116 not getting gas to the filter or carb
I can not get gas to the carb or filter on a John Deere 1116 Lawn Tractor. Where do I start to find the problem? Is there a fuel relay or an electric fuel pump on it?
It has a vacuume operated pump under the battery, by the steering column .it operates inconjunction with the pump screwed to front of the carb. id check the diphram in both, they dry rot and stop pumping if they sit
Posted on Sep 26, 2013
  • dumpfixxer
    dumpfixxer Sep 26, 2013
    ok, sorry let me clarify, the vacuume operated pump was an add on takeing the place of the electric pupm . sorry for the confusion
    Sergeant:
    Champion:
  • 212 Answers
It shouldn't have a electric fuel pump. What I would do first is take the gas tank off. Take the fuel line off. Drain the gas tank. blow thru the fuel line.put all back on and fill with gas and try again. I'm guessing it sat for awhile. when gas sits for awhile it gets tarnished.any little bit od debris that was in the gas tank could plug the fuel line. Hope that helps You out.
Posted on May 25, 2009
    Sniper:
  • 197 Answers
Fuel line is pinched between fuel tank and frame.You should see the line coming down the rear side of tank,grab it and see if its free to move.
Posted on Nov 14, 2009
John Deere 160 lawn tractor.
May have online fuel filter in line, need to check. Also could be wear in throttle shaft or housing in carburetor.
Aug 12, 2017 | John Deere Garden
John deere 116 no fuel to carb
Blocke inline filter, or if it has a pump, then this is not working.
Feb 29, 2012 | John Deere Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
I have a john deere lawn tractor, 125. i broke the cable that engages the blades, i bought a new one, but cant see where the spring hooks up, above the deck?
Above the deck and from left side you go across deck the the idler arm that has the flat side of belt going around pulley. About halfway across arm there is a small hole that spring hooks to.
Jun 13, 2011 | Rc2 116 John Deere 125 Lawn Tractor
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Not getting gas to the carb
There may a screen in the gas tank that is plugged. Drain gas from tank...inspect with flashlight. Clean screen with aresol carb cleaner and gently blow low pressure compressed air backwards through the fitting
Jun 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 116 lawn tractor
Call any John Deere dealer directly and they will tell you.
Apr 06, 2009 | Garden
Garden Logo
1,921 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
