Question about Sharp AR-5320 Black and White Copier
Smudges on paper and then when it does copy, ink is light.
Sharp SD-3062. 2 problems. 1) ink is light on paper. 2) it seems like until the copier warms up for a while, the copys have smudges all over the paper. It copys what you want but smudges are covering it. When it does apparently warm up, the paper is clear but the ink is still like no matter how dark you try to get it. The paper just turns dark.
Thanks,
dh
  • Anonymous Mar 27, 2014
    the ink doesn't dry so when copy comes out the ink smudges
  • 30 Answers
Hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
Posted on May 26, 2009
Sharp sf-2050 toner moter how to chuch moter is working or not working
in put key *c+interput+0+interput+10+start+1+start =active motore toner for 30 sec
Feb 07, 2014 | Sharp Sf 2050 3062 Compatible Copier Toner...
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
How fix error pc for sharp SD 3062 problem?
pc means: personal counter is not attached to the machine or not plugged in properly.
Feb 27, 2011 | Office Equipment & Supplies
Toner smears and smudges off copy.
The "fuser" unit is not working. It should be heating the ink and the paper, in order to "melt" the ink into the paper, to "fuse" the two components.
Call your local Canon office, and get a Service Call to inspect/replace the fuser unit.
Jan 27, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
Smudges on paper and ink is light when it does copy correctly.
It sounds like your drum unit needs to be replaced. Do the smudges look characteristically like a finger print? Technicians have a rule of thumb. Replace your drum, developer compound and general service the machine as often as you service your car. Assuming you do service your car as often as I do, it should be after every 25,000 copies. If the machine has never been serviced then its time you did.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Cannon Copier
Sounds like your drum cartridge might be bad.
Something you can try that might narrow down the problem is to make a copy of something and shut the copier OFF in mid copy.
(Basically, when the light is about 1/2 way finished scanning.)
Then, open the machine up and removed the jammed paper which should be 1/2 way through your machine and hopefully about 1/2 way under the drum/toner cartridge unit.
See how the copy looks at that point. **** FYI **** The toner on the paper is NOT FUSED so it will RUB OFF. Keep the paper away from your clothes and toss it.
IF your copy has smudges on it, then there is a real good chance that your drum unit is bad and needs to replaced.
If the copy looks good, then there is a possibility that the fuser unit is bad and needs to be repaired.
I would say that your drum unit is bad with my experience with Canon Copier.
If you still have more questions, feel free to ask.
Have a good day.
Good luck.
Mac
Mar 23, 2008 | Canon PC-D320 Copier
Black Smudges of the First Copy. Canon pixma ip 3000.
try cleaning all the runners that the paper uses on the printer. Clean the dabbing pads inside the printer too.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Sharp AR-5320 Black and White Copier Logo
272 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
