Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Water collecting in bottom of fridge
Have water collecting in the bottom of the unit, right under the fruit and veggie hydrator drawers. Have to soak it up at least 2x per month
NO SOLUTION!!!!
a ?
how do i stop it?
Posted on Jun 16, 2009
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
Where is water comming from found in bottom under veggie drawers
often a blocked drain. The drain pipe should empty on to a collection bowl on top of the compressor. If you can blow sharply up this pipe, the blockage should clear.
Apr 29, 2012 | Samsung RS2630SH Side by Side Refrigerator
54409 // water accumulates under veg and fruit drawers?
Look inside at the back to see if there is a collecting troff which collectes the water runing down the cool plate. In the middle of the troff is a run off hole which takes the water outside to the back to an evaporation tray. if this hole gets blocked it floods the fridge and you know the rest. Some fridges have a looped plug which you pull out of the troff hole to clear the blockage. I know this as my fridge does this too.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water collecting under veggie drawers on bottom
check to see if defrost hose is clogged under veggie drawers
Aug 02, 2009 | Kenmore Refrigerators
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
Jun 16, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
388 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
