Computer Turn then a flash of white type with a black background
The black background and white type stays on for a split second and then black screen.
The power light stays on
  • visacomusa May 29, 2009
    Thanks haayz.
    However I do not know how to hook up an external monitor or to see if the video driver is correctly installed.
  • 197 Answers
Connect your machine in an external monitor to check if the display is okay on the external monitor. if yes, the problem would the the LCD screen from your laptop. you might need to replace it. also, check if the video driver is correctly installed. if not, re-insatall your video driver. if there's no display on both panel i suspected it's a motherboard faulty.
Posted on May 29, 2009
  • iya velasco
    iya velasco May 30, 2009
    on your laptop, you will see a port. Connect the cable from you external monitor to the port from the laptop. Check the cable from the external monitor (there is only one port to fit the cable to the laptop)
Iinstaled win xp, now monitor will not work. can i download and install driver onto flash drive without seeing my monitor
Turn your notebook off.
Turn your notebook on, and immediately start pressing the F8 key, once or twice per second,
until you see the Windows "start-up" menu (white text over a black background).
Choose the "start in VGA (low-resolution") mode" (or some wording similar to that).
You computer will start-up in '800-by-600-by-256-colours' mode, which should work.
Adjust the screen-resolution, and the number of colours to "optimal" values.
Jan 31, 2011 | KDS Valiant 6480iPTD Notebook
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
Second and subsequent pages in scan are blue
we called the HP tech and they replaced the board, seems to be te only solution
Nov 23, 2008 | HP 9200C Digital Sender
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
My c250 turns on, but not in the way I would like it.
Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Screen problem
use your remote and change to AV1 sys 1
Jan 03, 2008 | Legacy LSWR82IR 8 in. Car Monitor
My Sandisk Wont Turn Stay On
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e260 MP3 Player
V3 razr goes to white screen
software problem u must contact service center and do flash it
Jun 15, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
