Question about Motorola Talkabout T5210 2-Way Radio
Very low volume on T5210
I have the T5210 series TalkAbout. The problem is that one set has alot of volume and the other can bearly be heard. Installed new batteries, switched batteries, nothing. They are on the same channel, one is loud the other has no volume (very low). Thanks
  • Motorola Master
  • 1,654 Answers
Sorry to hear of your difficulty. There are a few things which come to mind. First, if you have only two radios, check the good radio to see if anything is plugging or covering the mic hole. Then if the good radio is not the problem, check the bad radio for debris or something covering the speaker holes. If this does not reveal a problem, the next issues are possible, but not resolveable: You either have a bad volume potentiometer (internal volume device) or your speaker is bad.
Posted on May 25, 2009
I want to switch to silent mode
On most Motorola TalkAbout radios the roger beep can be turned on or off by holding in the PLUS (+) button while turning on the radio.
Best regards.
Oct 31, 2012 | Motorola Talkabout T5210 2-Way Radio
How do I turn off the beep when I key the mic on the Motorola Talkabout 5210?
Press and hold the + (plus) button while turning the radio on. This will turn the Roger Beep on or off.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXx_User_Manual_E.pdf, you can find the instructions on page 7.
Best regards.
Nov 28, 2010 | Motorola Talkabout T5210 2-Way Radio
Instruction manual
Here is a link to the 5200 series user manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XxX_User_Manual_E.pdf
Check your Frequency, interfernence Code eliminator and Qt filter (if any). These all should match each other on all your radios.
Another issue which will cause a radio to receive but not transmit is a low or bad battery. It takes more energy to transmit, than to receive.
Best regards.
Nov 28, 2009 | Motorola Talkabout T5210 2-Way Radio
How do i stop my radio from making that bloop bloop noise after i key it
You are either describing a CALL TONE ( The Call Tone obtains others’ attention before you start talking) or the ROGER BEEP (When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.)
To shut off the roger beep, hold in the plus + button while turning the radio on.
The CALL TONE may or may not be a feature of your T5210 radio. I am unable to open the online manual for it to tell for certain. If it does have a CALL TONE feature you would access it by pressing the MENU button until you see a "CA" on the screen along with a number. Using the plus or minus button change the setting to zero, followed by pressing the menu button or the PTT button. The zero setting is equivalent to OFF.
To
Oct 01, 2009 | Motorola Talkabout T5210 2-Way Radio
One walkie talkies volume is very low
Check the speaker grill and the mic hole for dirt or debris.
Nov 15, 2008 | Motorola Talkabout T5100 (14 Channels)...
Vibrate
Press and hold the minus button while turning on your radio to turn on or off your keypad tones.
To turn the roger beep on or off, hold in the plus button while turning on the radio.
Here's a link to the manual direct.motorola.com/ENS/T6500%20Series%20User%20Manual.pdf
Aug 25, 2008 | Motorola Talkabout T6500 (7 Channels)...
Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 31, 2008 | Motorola TalkAbout T5530 2-Way Radio
Moto talkabout t5210
I have a set, in great shape too. Make an offer.
Pilo
prios1@hotmail.com
Aug 12, 2007 | Motorola Talkabout T5210 2-Way Radio
Were can I buy the walkie talkie Motorola Talkabout T5210 2-Way Radio? thanks...
go to wal mart buy 2 set new cost 30 to 40 pair near to you att franco
May 12, 2007 | Motorola Talkabout T5210 2-Way Radio
Motorola Talkabout T5210 2-Way Radio Logo
685 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
