Question about Sony VAIO Notebook
PCG-7Q1M WONT LOAD UP
Switch on laptop but it wont load xp from hard drive
    Problem Solver:
  • 7 Answers
Wipe your drives and Reinstall windows XP
Posted on May 25, 2009
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
Hi, When I switch my laptop (Sony Vaio, Model: PCG-7Q1M) on. I receive an message stating, "Operating System not found". The laptop was dropped a few days ago. The laptop attempts to read from...
Hi.
Based on the information you have provided, it seems that the issue might be due to the Hard Drive.
As you have mentioned that the Notebook was dropped, this might have caused a Physical damage to the Hard Drive.
Hence, the Computer might not be detecting the Hard Drive.
As the issue might be Hardware related, it would be better to get the Unit examined at the Sony Authorized Service Center.
Before sending the Unit to the Service Center, you may try resetting the BIOS to its default values.
Performing the BIOS reset should resolve the issue.
If the issue still persists even after performing the BIOS reset, then you may get the examined at the Sony Service Center.
You may initiate the Service by filling the required details in the below link:
https://eservice.sony.com/webrma/web/index.do
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 22, 2010 | Sony VAIO Notebook
Sony vio vgn b3vp when loading windows wont see hard drive
Hi, your hard drive is partitioned for XP, go back to this stage of setting up the hard drive, delete patition and start again.
Jul 29, 2010 | Sony Computers & Internet
It wont load windows xp all of a sudden,payed and down loaded windows xp recovery disk when i went through that it was runing a different program which let go into my hard drive but wont run any of the...
It could be possible if the hard drive isnt too far gone, are you able to use it at all? have you tried to hook it up to a different laptop and see if you can access it from that? You'll probably be better off getting a list of anything that you can re-download and storing the irreplaceable stuff such as sensitive documents onto a disk. If you can do this then just reformat the hard disk and get it over with. You stand to be in for quite a headache trying to copy all your files off your hard disk and making sure all the files arent corrupted. This stands especially true if your hard disk has malware or a virus.
Jan 10, 2010 | Panasonic Toughbook 48 Notebook
Wont load correctly
check the hard drive.western digital hard drives work good in this computer. ihave two of them.also windows xp home works good on this.or run the system recovery cd.lastly' re do the
windows installation.
Jun 03, 2009 | Gateway Essential 400 PC Desktop
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
Problem Installing XP
you can go to your BIOS system set up and select the right sequence if you prefere HDD first then CD-ROM,
depends on your manufacturers settitng pls press F2 or F10 immediately upon start up then you will be prompted to enter password, ( if you know ) then scroll down until you see the booting sequence, dont forget to save this and end your system set up
goodluck
Aug 06, 2008 | Sony PCG-TR3A Notebook
SONY VAIO PCG-7G1M Wont boot
First you understand yourself is that after the windows logo screen apperars and its get restart means there is some changes or malfunction happened to your hardware - Although you changed your hard disk will not solve your problem. Please clarify as follows
1) did you load you operating system to this hard disk by any other computer help - if you load it with the same system try to reinstall the system.
If the problem existing 100% your motherboard is partially damage I think the uniprocessor side voltage variation is happening while you press keyboard some charge (voltage) you are supplying to the motherboard, sometimes some key pulse is more than 5 volt so that pulse support to get moved some points
First check your windows try to reinstall agian - I predict that you got this hard disk installed through some other laptop so the hardware configuration is different.
Thanks Hothawk
Jul 17, 2008 | Computers & Internet
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
Sony VAIO Notebook Logo
211 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
