Question about Whirlpool Duet GHW9150P Front Load Washer
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Just bought new Whirlpool duet washer WFW9200SQ and when we first started it F32 comes on and the washer will go no further.
  • 15,935 Answers
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Nov 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Front Load - Code F 32 - Cannot open door
F32 is the code for Pressure Switch Failure. Which is only found on a tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not start
This is joyce
Go to whirlpool.com and download your document to your machine and see what it has to say about your particular machine if that will help if not you may have to get some proff. help.
thanks
joyce
Feb 19, 2009 | Washing Machines
Whirlpool Duet 9200 Washer door lock issue
no thiis is normal operation, it is considered a child safety feature. in case a sleeping child should happen to be in machine, the short 2 sec blast of cold water will wake them and give them a chance to exit before the machine starts washing.. all whirlpool frontloaders do this, thats how it waas explained to us at factory training.
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet HT WFW9200SQ/A
Plug off the wall. Close the wall faucet and check the hose & small screens on it. Open the faucet to see if the flow and pressure is good (keep bucket handy). Refit carefully, try machine. Code is nt seen anywhere as you said.
Jan 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
252 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
