Question about Yamaha Full-Size Keyboard
I JUST WANT TO LEARN HOW TO PLAY AND BY HEARING
I DO NOT KNOW HOW TO PLAY AN ORGAN
    President:
  • 2,976 Answers
I used to own a sheet music store. There are about 50 different piand & organ methods available. The Theodore Pressor series is a good starter.
Posted on Jul 07, 2009
  • 31 Answers
Lol kind of complicated. may i recommend a local church player, they probably know a good deal about them
Posted on May 25, 2009
I believe organ hasn't been played or even turned on in over 10 years. The top keyboard plays if I turn on a setting such as piano or trumpet however I can't just get the organ keys to play.
Since the organ has not been used for a long time, I suspect that there can be degradation of the electronics, specially with electrolytic capacitors. hence I request you to switch on the Organ continuously and allow it to warm up, it there is improvement , then it will be worth to remove the bottom panel and clean up the boards,dry the PCB with a hair dryer and reconnect the boards.
Hope this will help.
Jan 23, 2016 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
How can I turn off the sound to the foot pedals of my Lowery organ. Is there any setting on the organ to do that?
If you turn off any voice tabs for the pedals, they are effectivly turned off.
Mar 22, 2015 | Music
Thomas playmate color glo organ series 1200
This is not one of the newest organs around. The organ still could have real switches. Like silver threads touching when a key is pressed. sully some oxidation on these contacts should not be noticed while playing, but if you can reach the contacts, try some Contact cleaner on the contacts like Deoxit in the US and Kontact 60 in Europe.
Jul 13, 2014 | Music
Technics organ will not play
Need more info.... using line out or does it have built in speakers, make sure if it uses an ac power adapter that it is the correct one (AC vs DC output and voltage\amp rating makes a difference). Is it moved often, was anything dropped or spilled on it, etc? Age... model number and you say organ I'm guessing it's actually an electronic keyboard?
Jul 04, 2013 | Music
Need a manual for old hammond organ model 122126 romance model or 1977 or 1978
You might try the ORGANFORUM.com as there are a lot of organ players there and quite a few with Hammonds. Finding an original copy is probably out of the question, but a duplication probably can be found.
Jul 15, 2011 | Hal Leonard Classic Hammond Organ Know the...
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
THE U &L SOLO PANEL PLAYS VERY LOW NO VOLUME YOU CAN HEAR IT VERY LOW WHEN VOLUME IS SET AT HIGH AND SWELL IS AT HIGH ALL WORKS JUST NO VOLUME
Who would have any idea of what make or model device you have? Sounds like some brand of organ. We are not mind readers on this forum.
Oct 14, 2010 | Music
Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
May 05, 2010 | Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
Yamaha Full-Size Keyboard Logo
231 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
