Question about Toshiba Satellite Pro 6100 Notebook
Nothing appears on my monitor
When I turned on my laptop this morning, it made this quiet, high-pitched whining sound and the screen wouldn't load up. I turned the computer off again and turned it back on and this time the screen came up fine but after a minute it went to black and white and then completely away again. After a third restart, it didn't load up at all and hasn't after subsequent tries either.
  • 31 Answers
Might be dead... try to leave it off for w while before trying again. check all connectors and if it still faisl to work your going to have to get a new one. Before that check your warranty and dealer and se if anything is coverd. best of luck
Posted on May 25, 2009
2005 Chevy Silverado 6.6 turbo diesel 3500 4x4 can't pull heavy loads
Do you hear the turbo whine/high pitched noise when it's pulling?Do you know for a fact if the turbo is working?Is fuel pressure correct? Is the exhaust system sound very quiet?If it does then it may be restricted.
Feb 18, 2018 | Chevrolet Silverado Cars & Trucks
High-pitched whine upon cranking, suddenly sluggish, smells hot
It sounds like the water pump shaft bearing has frozen up. A hint here, always replace the idler pulley and water pump when you do the belt, they make kits for this and they have all the parts that wear out along with the belt. As long as the engine doesn't get to hot you should be ok.
Jul 02, 2012 | 2000 Honda CR-V
A noise had been gradually increasing from a grinding sound to a high-pitched whine. COntinues until the screen is completely off. Sounds like a fan motor may be out of lubrication.
THAT TV HAS WHAT IS CALLED A COLOR WHEEL WHICH SPINS AT VERY HIGH RPMS AND CAN MAKE HIGH PITCHED WHINING/GRINDING NOISES IF A FAN WAS BAD THE TV WOULD SHUTDOWN AND THE SOUND WOULD BE MORE DULL SOUNDING.
Dec 17, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Whining noise
your mic is on remove your mic friend
best of luck
Oct 26, 2007 | Microsoft HP Pavilion DV6276US Notebook PC
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Mixer whine
Unfortunately, the Kenmore mixer sounds louder than freight train due to a poor planetary gear design. I had to take mine back so that the neighbors wouldn't **** me. I hooked up two identical models at the store to get the same, painfully loud, experience. I think I prefer the sound of a bandsaw to the grating noise it produced.
Jan 01, 2006 | Kenmore KSM100 Stand Mixer
Toshiba Satellite Pro 6100 Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
