Question about EW3100 Radar Detector
No audio output
The voice output was slowly getting weak and now it has ceased. It used to tell you to buckle up on start-up, but that has ceased. All the lights seem to be working.
    Scholar:
  • 36 Answers
Well besides the obvious of voice off/on the speaker could be blown. I have one of these units but have not cracked it open. My speaker has blown twice on my passport 9500i and I just replaced it myself. It's out of warrantee and Escort wouldn't send me a speaker, so I got one from radio shack and that worked for a while, then blew. I used a laptop internal speaker now and that works great ! BTW if the speaker on this unit is soldered to the board good luck, like I said I haven't cracked my ew3100 open yet.
Posted on Dec 25, 2009
How to change the default voice
Try this,
1. Click Start, click Control Panel, and then double-click Speech. 2. On the Text-to-Speech tab, click Audio Output. 3. Select either Use preferred audio output device.
If this works and helpful, please give a testimonial and vote by pressing button thumbs
up icon.
Sincerely, Thiyaga
Aug 27, 2011 | Microsoft Windows XP Professional
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
I have a behringer PMP 3000 mixer, on e of the channel is gone, it is not under warranty, can you tell me who can repair it ? what causes the channel to blow.
Often the A channel power output blows. CEASE using the unit immediately until repaired as continued use can have additional damage to power supply.
Any problem with speakers can blow the channel as there is real weak insulation on a multi-layer circuit board in the rear most amp (channel A). It burns and takes out three transistors on the HCA2400 module inside.
ALSO read my tip on here regarding a hazard of Behringer PMP units due to the channel A connection when using Speakon to 1/4 inch plugs or adapters having the BARREL being the hot lead instead of the TIP of the 1/4 inch plug. Short that barrel to ANY ground and goodbye channel A.
Jan 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Fram my radio gp338, the audio becomes slowly goes
if when you are transmiting your voice level is falling down in the others radios, this is a modulation problem, try with an audio accesory if you voice level or modulation level keeps constant your radio need to be repaired. if your problem is when you are receiving a communication, may be the speaker needs to be replaced
Jan 02, 2010 | Radio Communications
Amp has no output
Most likely the power supply has failed. Could be any component in the power supply section. Best to have a competent tech. check it out.
Mar 30, 2009 | Crown-Audio XLS 402D Amplif 300 with 8o...
Alpine cda-9853 no CD audio
do you have an amplifier powering your speakers? if so make sure you have the correct remote wire and not the auto antenna wire
Sep 15, 2008 | Alpine CDA-9853 CD Player
Headset
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
EW3100 Radar Detector Logo
104 people viewed this question
Top EarlyWarning Vehicle Parts & Accessories Experts
Aaron Hackbarth
Level 1 Expert
Chris Larocque
Tom Chichester
Are you an EarlyWarning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
