It calls for five degree of timing and the only mark numbered is ten degrees which one is five degrees do i go between the hash marks
SOURCE: timing engine
I had a 2.4 L engine in a caravan and replace the water pump that was controlled by the timing belt.
I was having the same problem, I called my bother in law to help. The crank shaft has to stay perfectly timing on the low end. The cam shaft marks are set exactly one half of a tooth apart. So when looking at it, The left side cam gear mark is a half a tooth higher then the right side. Then you have to try and slip on the belt . That is the easy part. When letting go of the timing belt tensioner the marks should line up perfectly across from each other. You have to take off the belt again and make sure you keep correct tension on the crank shaft so the mark is not moving when you are putting on the belt. There is a web site call Alldata.com. The web site cost a few dollars but it willl give you a detail instructions on how to time the engine with pictures to guide you. This is the same web site the pro's use.
I hope this has been helpful.
Oh, by the way you are lucky because the engine is not an interferrence type , so you can not damage the valves at least. Since you know the oil pump is out of time , check all the spark plugs again , they are probably oil soaked .
SOURCE: Looking for the timing mark
Hello bojak80,
The basic timing is 5 deg. BTDC. Below is a picture of the timing mark. I hope this helps you.
Regards,
netvan
Intake, 0.007-0.009 in (0.18-0.22mm).
Exhaust, 0.009-0.011 in. (0.23-0.27mm)
Civic
1.7L Engine
NOTE
Adjust valves only when the cylinder head temperature is less than 100 degrees F.
