Question about General Electric WCSR2090D Top Load Washer
OVERFILLED AND FLOODED HOUSE
WASHER OVERFILLS AND FLOODED HOUSE.
  • mecakcsac May 25, 2009
    This problem happened once and since we have been watching carefully. It is working for the time being. It also fails to fill in rinse cycle sometimes.
  • marionbagget May 11, 2010
    You should also look into other means to prevent the house from being flooded. Search the internet and talk to big box stores and plumbers for solutions. Mold growing in the house walls is far more costly than a new machine.
    President:
  • 1,902 Answers
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
Posted on May 25, 2009
  • Jeremy Reddick
    Jeremy Reddick May 25, 2009
    If it is having problems wanting to not fill in the rinse cycle then this sounds like a timer issue. Which could cause flooding. We had a problem at our house where actually it was flooding from drain in the house was broken and not allowing the water to drain properly. So that is just another recommendation to look for.
Amana top load washer overfills with hot water and wont stop unless you shut supply off. NTW5400TQ1
Okay you say only hot water if you unplug does water still come in if so bad inlet valve if it does it on both then the pressure switch is bad or there is a hole in the tube that goes from tub to pressure switch
Feb 17, 2015 | Amana NTW5400TQ Top Load Washer
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
The washer overfills
if you unplug it and the water keeps running replace the valve where the hoses are connected to but if it overfills and the water stops when you pull the plug replace the pressure switch
Jan 16, 2013 | Kenmore 98702 Stacked Washer/Dryer
What does E2 mean? Thanks
Hi, E2 means that anti flood device has been activated. The machine has overfilled.
Check in the base (under the bit you put the dishes in) to see if it's flooded. The causes for overfilling are blockages in the metering tank, blockages in the system hoses.
Drain the water out of the base and try the machine again. If it overfills you'll need to take the machine out, do a fair bit of dismantling to get at the hoses etc. to clear the blockages.
Jun 21, 2011 | Belling 24 in. IDW602 Built-in Dishwasher
Icemaker in refrigerator overfills with water
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips after it is supposed to stop, replace the water inlet valve on the back where the house water supply comes in.
Oct 14, 2009 | Kenmore 53642 / 53644 Side by Side...
Simpson Electronic water not stopping
Pressure switch - it measures the weight of the water (in bars) and tells the valve to close.
Check/replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Washing Machines
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Maytag washing machine
if overfills only when turned on suspect waterlevel control or small hose from control to base of tub ..look for holes in tubing or crud plugging hose usually on end at tub base
May 29, 2008 | Washing Machines
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
General Electric WCSR2090D Top Load Washer Logo
364 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
