Question about TDK (CD-RW74HSFXS5) Storage Media
Locked out I bought a flash drive that is lock protected and when I tried to set my password it locked me out. The flashdrive is a TDK Trans-IT
  • Anonymous Nov 22, 2007
    I have the same problem as the user below. I bought an TDK TANS-IT 2GB FLASH MEMORY STICK and there I THINK was alredy a password on... how can I change it. It was comletely new. ??? THX
  • Anonymous Mar 13, 2014
    how to recover forgotten password on tdk flashdrive
Http://www.tdk-media.eu/downloads/trans_it_usb_password_pr_english.exe
Posted on Jan 15, 2009
Forgotten password on TDK memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Hope this helps
Mar 13, 2012 | TDK (CD-RW74HSFXS5) Storage Media
My password protected scandisc cruzer usb stick is refusing to accept the correct password-any solution
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS lock or NUM lock is not turned on. You should try to type your password in another application (like word or email) to ensure that it is being entered correctly. This can help you see if CAPS lock, NUM lock, or a sticky key is causing the password to actually be entered incorrectly.
Password attempts
There's a set number of attempts before U3 locks your device and you have to reformat it.
Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password you will have to reformat the drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Jan 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
The flask card was formatted and the lock too.
TDK-branded USB drives with built-in TRANS-IT security.
"Flash Lock" password system security:
TRANS IT USB Password protection software (english)
Feb 02, 2010 | Electronics - Others
I have mistakenly formated my TDK 8GB TRANS-IT FLASHDRIVE and altough it is empty it looks only 9.95MB capacity. Any suggestion to solve this?
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it.
Try formatting using Disk manager.
Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Dec 19, 2009 | TDK (CD-RW74HSFXS5) Storage Media
8gb TDK trans-it flash memory is invisible
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 18, 2009 | Imation Products - imation - Clip Flash...
Pen drive not working
You need the flash lock programme.
Here is the link, its the TDK japan site, download is bottom left ish.
http://translate.google.co.uk/translate?hl=en&sl=ja&u=http://www.tdk-media.jp/download/dwn00200.html&ei=p1aaSpr_JeKhjAf4-5SkBQ&sa=X&oi=translate&resnum=4&ct=result&prev=/search%3Fq%3DTDK%2BFlashLockV222.exe%26hl%3Den%26sa%3DG
AndystUK
Aug 30, 2009 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How to remove write protect on my usb flash drive
On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
Oct 08, 2008 | Computers & Internet
Tdk trans it 4GB secure area missing
hi sir
sir my flash automatic write protect . tdk 2 gb
Sep 19, 2008 | TDK (CD-RW74HSFXS5) Storage Media
TDK (CD-RW74HSFXS5) Storage Media Logo
1,892 people viewed this question
Top TDK Electronics - Others Experts
Alun Cox
 Grubhead
Grubhead
Jim Goldsmith
Jim Goldsmith
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
