Exhaust pipe too short
I am looking to buy an extension for the exhaust pipe for my portable air conditionner
    President:
  • 1,902 Answers
Exhaust pipe for what? For the condensing water? Can you please make it clear what you are looking for
Posted on May 25, 2009
Is Portable AC worth the buy ?
split system is better option. more expensive but more dependable.
Sep 08, 2015 | Heating & Cooling
How do you replace 97- plymouth voyager belt tensioner
For the 1997 3.0 liter Grand Voyager:
Remove A/C belt. Release tension on serpentine belt by moving the tensioner, then remove the belt. Be sure to note how the belt is routed.
From way back underneath the car look up along the exhaust pipe leading to the rear manifold, you can just see the bolt on the back of the tensioner to the right of the rightmost spark plug boot (looking forward from under the engine). Route a socket (15 mm I think) on a short extension up along the exhaust pipe and shield (make sure it's cold!), you can just get it onto the bolt. Then snake a socket up and connect to the extension, no universal joints needed. There's just enough room to get enough leverage on the bolt to remove it. From then on it's simple.
I replaced my tensioner a few hours ago as above.
Mar 21, 2012 | 1997 Plymouth Voyager
I just bought a portable air conditioner model c120e. Unfortunately the exhaust hose is too short to use in my window. I have a home built in the mid 60's so the window ledge is higher than in more...
rlee - we don't stock or sell parts here on the FixYa website. We simply provide information on how to troubleshoot and solve problems with a host of things. However, you can find what you're looking for at any home center in the heating & air conditioning dept. What you need is pretty generic, but you'll have to buy more than what you need and cut it to size. Will it be identical? Probably not. But it will accomplish what you want and need to do. Be sure to take a section of your existing tubing with you, for comparison purposes.
Hope this helped you. Please let me know.
Jun 03, 2011 | DeLonghi Heating & Cooling
I want to buy portable air conditioner, but the buyer said that i need put the exhaust tube near a window open to expel hot air, in my room not have windows
You do have to use the exhaust tube, would need to put a hole in your wall. Also, these units really generate a lot of heat. We tried one, it almost seems as if it actually makes the room hotter! You would be better off buying a small regular unit, constructing a hole in the wall to the outside.
If you absolutely cannot do the hole, you could get an extension to the exhaust tubing and maybe use a window in another room?
Apr 04, 2011 | Heating & Cooling
My vent is too short on my amcor model ALTL 12000E portable ac
Try to extend the pipe using a pvc pipe or, some sort of pipe.use alluminum tape that you can get at your local hardwhare store to seal the crack in the pipe that you use to extend..
May 27, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Fitting vents in the window
Mike,
what I usually do in this case is to remove one side of the curtains. This is usually the fastest and I have not been able to find factory curtains that are any narrower than whats on the A/C out of the box. Good Luck and have a great day.
Contact me back if I can help you any more.
Sincerely,
Paul Gibson
May 02, 2010 | Royal Sovereign ARP-1000EX Portable Air...
What causs downdraft on a stove?
Purchase a extension pipe along with a cap. These caps allow the exhaust to escape but discourage reverse air flow they look like and upside down funnel.
Dec 08, 2009 | Blue Rhino Outdoor Wood Burning Fireplace...
9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Aug 18, 2009 | Maytag Electronic Portable Air Conditioner...
Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
May 16, 2009 | Danby DPAC12031 Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
