Question about Samsung HLR5667W 56" Rear Projection HDTV
No picture on tv all three lights flashing on front of tv.
When u turn on the tv it will start up but never gets a picture on the screen. It eventually turns itself back off & all 3 of the lights flash on the front of the tv.
  • Samsung Master
  • 8,617 Answers
Three blinking LEDs mean lamp may be defective replace the lamp.
Posted on May 25, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Theres blue lines on my sony kf-42sx300u tv fell over and the mirror inside broke, so i bought a old tv for spares, rebuilt the tv first the lamp cover wasnt secured correctly thus making the tv not turn...
This is a simple fix and not hard to do, first you must get the speaker grill off, usaly two screws on the bottom and they might be hidden under to caps, then remove the acsess cover from the front. From there you should see a control box with six controls, three on top of three,,,,One part label "screen" the other "focus" now turn the set on and tune to a input that HAS NO SIGNAL this should give you a black pix, probley not now but it's supose to be black. Now turn the ones marked screen , one at a time counter clockwise just a little to get the pix compleatly black, now starting with one color turn the control slowly clockwise till the color just appears then turn it back down till it just disapears (Black) do this for all three colors Now the set should runn
Dec 29, 2009 | Televison & Video
TV PICTURE GOES OUT AND THEN SHUTS OFF
sounds like dodgy buffer board or video pcb
Sep 25, 2009 | Televison & Video
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Samsung HLR5667W 56" Rear Projection HDTV Logo
424 people viewed this question
Henry  Thomas
Henry Thomas
