Question about Samsung Refrigerators
RS2555SL - Replacing the relay step-by-stemp
How can I remove the plastic cover covering the relay on the compressor on my Samsung RS2555SL fridge? Thanks!
It wasnt too hard, I was trying and trying because I dint want to brake the cover, but I used a flat screwdriver and realeased the plastic cover from the top, it has a little tab, push it up and it will realese the cover, I hope it help you, by the way the realy you can get it at ebay for $7.00, I got it there
Posted on Jul 09, 2009
Thanks, Jonathan! I got the relay replaced and my fridge is working like new!
Posted on Jun 16, 2009
Samsung Refrig Compressor Problem
Can you tell where the hum is coming from?
Jul 10, 2013 | Refrigerators
Fridge tripping the breaker
I don't recommend replacing any parts on your refrigerator until you determine that the compressor is not shorting to ground. Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Mar 19, 2013 | Samsung 24.0 Cu. Ft. Side By Side...
VinoTemp VT60
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20 from AppliancePartsPro
First, unplug the wine cooler and take off the back panel. The back panel is held into place with several philips head screws.
Step 2:
Locate the compressor. You'll find the compressor in the bottom left corner of the VT-60 as viewed from the back. You will see copper tubes coming out of the compressor. These tubes carry the compressed refrigerant to the evaporator assembly. Be careful not to crimp or damage the copper tubing.
Step 3:
Find the black plastic cover to the left of the compressor. This cover is held into place with one philips head screw. Remove the screw and remove the cover to find the PTC start relay.
Step 4:
The relay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Slide the relay on the connector pins, reattach the blade connector, reattach the black pastic cover over the relay, reattach the back panel onto the VT-60 and you're done.
Nov 28, 2012 | VinoTemp (VT60GNV) Wine Cooler
Vinotemp not staying cool, it's set at 54 degrees, but it's at 82 degrees
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20.
Step 2:
Step 3:
Step 4:
The replay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Sep 09, 2011 | VinoTemp VT-60 Wine Cooler
Samsung american fridge freezer, not freezing, clicking noise at the back of the fridge
Your PTC relay is bad and needs to be replaced. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken If the part is way expensive you can replace with a 3 in 1 relay for refrigerators alot cheapier and work just as good.
Jan 31, 2010 | Samsung Refrigerators
The Compressor won't start
If you have one try it ,if not , replace the relay which is the one that usually fails in this type of compresors .if still won't start , the compresor is either burned out or stuck and needs to be replaced.
Aug 09, 2009 | Refrigerators
Clicking noise coming from whirlpool refrigerator
Jan 18, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Samsung RS2555SL Not Cooling/Compressor won't start and cycles.
Jonathan is the solution!
It has been 24 hours since my fridgerator has started with the occasional clicking then not cooling. I started on the google hunt and found this website with Jonathan's post. I am a 26 year old female stay at home mom of 2 toddlers. I printed the page of Jonathans success and took it to my local parts store. I purchased the Mars start relay for 16 bucks. I pulled the refrigerator out from the wall and took the back apart and followed Jonathans instructions and I had success. You are a savior! I could never afford a repair man. Thank you so much for your post!!!
Oct 31, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
904 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
