Question about LG Washing Machines
Fix rust spots by dispensure
How do i pop off the top of a LG 1832CW washer. Do I pry it off with two screwdrivers on the front of the washer?
Their are two spring clips in the front of the washer that need to be pushed in with screwdrivers and the top flips open.
Posted on May 26, 2009
Very loud during cycle
most top loading machines have clips that attachthe top to the front, pry up on top with small pry bar or screwdriver. if noise is a banging noise, you may have a spring that broke or came off underneath machine. i would check under washer before removing top.
Nov 10, 2013 | Maytag Washing Machines
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Why does my lg front loader washer wm-1832cw sometimes give anle code and sometimes works
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
Jun 03, 2011 | LG WM-1832C Front Load Washer
Some time after the cycle has finished I still can't open the door. It has been progressively getting harder, but now won't budge
For now, pry it with a flathead screwdriver, or similar "tool." Once opened, check the locking connection that it has, press a flathead screwdriver that will fit in that slot into it, and see if the lock pin rollers spread apart easily, if it gives too much pressure, then the answer is obvious, the grease on them's beginning (or started long ago to wear off, and they're jamming up, otherwise known as locking. There's not really a simple fix for this, since you'd probably have to take the whole washers frame apart, and lift it off the unit in order to access it IF this is the cause. Perhaps the hinges are rusting? other than that, not really anything that I can come up with. Call local repair facilities, and ask if anyone will just look at it for free, some mom and pop shops wil just for the sake of good nature, and business promotion :)
Jan 08, 2011 | LG WM1814CW Front Load Washer
The washing machine is rusted under the lid. How do I take the top off so that I can repaint? The model is RAX7245KQO. I need to take the top of the cabinet off to repaint. I need directions as to how to...
you have to use ether a screwdriver of a wedge in the seal about a inch below the top and pry up it is held by strong spring clips it will take some work when done you just pop it down unplug unit first hope this helps
Aug 30, 2010 | Roper RAX7244KQ Top Load Washer
Sharp calculator Model number,EL-506A how do i change battery
Take out the top 2 screws on the back, then you have to carefully pry the cover all the way off. Use a small screwdriver and pry gently at different spots around the split sides until some pop apart.
Mar 10, 2010 | Sharp Office Equipment & Supplies
How do I take top off front loading washer
It "pops" up by prying up with a very wide blade flat-tip screwdriver under each front corner. Putting tape on the tip of the screwdriver will minimize risk of scratching finish.
Charlie
Aug 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Need to clean inside washer surfaces
On each of the two front corners, insert a large slotted-screwdriver (or a stiff putty knife) in the crack between the top and the cabinet. Pry up -- the top should pop up.
Apr 21, 2009 | Maytag MAV3905AWW Dependable Clean Top...
Lg 1832cw
Mike, you don't need to yse any glue cause it is a press fit bearing. I had to do the same thing. I was able to go to my local bearing supply for replacements. And it was much cheaper that going to an online place to buy them. It pay s to search.
Jim
Nov 16, 2008 | LG WM-1832C Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
200 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
