Question about Craftsman Garden
Belt replacement LT2000 Model917-273750
New belts are in place and remain engaged?
  • 376 Answers
Are you saying the blades start turning when you crank your mower? If so, you either have the wrong belt (should be # 144959) or have it routed incorrectly. Belt should go straight across the back between the spindle (blade) pulleys, then, in front of those, to the inside of both smaller, idler pulleys and then to the engine. Be sure to work the belt down between the pulleys and the flat, metal belt keepers on each idler pulley.
Posted on May 25, 2009
Deck belt engages but wont stay on
Make sure the belt keepers around the blade spindle pulleys are in place they are designed to keep the belts from coming off the pulley adjust to about 1/8-1/4 inches from the pulley...also make sure the belt tensioner is tight on the drive belt when engaged if it isn't your belts probably need renewed..good luck...
Jun 24, 2015 | Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
Dixon speedztr belt is loose when I try to engage won't work
look to see if the belt is on all the pulleys and all the linkage rods are in place
Apr 20, 2012 | Garden
Craftsman LT2000 Blade is staying engaged all the time, just did a blade mandrel replacement, where does the spring for the blade control reattach? What would make the blades be in motion all the time?...
sounds like you may not have the right mandrels making the belt to tight and it cant be left loose enough to allow the blades to quit turning.Otherwise you didnt put the belt back on correctly if it is around the tightener pully the wrong way that to will make the belt to tight
Apr 09, 2012 | Craftsman Garden
Garden Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
