Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Olevia 26" hdtv - sound, no picture
By MarjIndex on May 25, 2009
Set is about 1.5 years old, and has no picture. A cable tech said he thinks it's the equivalent of the picture tube going bad (crystals?). If so, is it worth repairing?
Thank you.
Best Solution
posted on May 25, 2009
Helpful)
pgh_pa_guy
Rank: Guru
Rating: 91%, 701 votes
If this is an LCD TV, it's probably the backilight inverter that's gone bad. Without the backlight, the display works but you can't see it. It may be possible to repair the set by replacing the inverter. Several sites sell boards removed from other sets (the TV version of an auto junkyard). One of them is shopjimmy.com. You can also try a Google search for "replacement inverter" for your specific TV model.
If you can find the replacement board, it's not difficult to change. It's a matter of removing the back of the set, unplugging the cables from the old part and connecting the new one in its place. Rather than relying on the cable tech (they normally don't know anything about TVs beyond where to hook up the cable), you might want to get an estimate from a TV technician if you don't feel you can attempt the repair yourself.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
romsky79
Rank: Wiz
Rating: 77%, 403 votes
its a service mode only.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how to unlock channels
Answer
Answer
LG 20" LCD TV will not remember all of the auto programmed channels and cannot program... (More)
Answer
Half screen goes black from time to time
Answer
can't control the volumn with or without remote. the volumn is on low and can't turn it up from the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
