Question about PfaFF Quilt & Craft Pro 7530
Changing needle-what size allen wrench.
Anyone know the size of Allen wrench to use to replace needle on Pfaff 794 serger?
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: serger 794 from pfaff--calanda type 794
There are two holes running vertically inside the needle arm.........the needles are held firm by very small screws or hex allen keys.........they may have worked loose over time, if they have fallen out and been lost, it is a call to your  local Pfaff dealer for advice......be sure to quote model number.
Your User manual may have a diagram to assist.
Have you ever changed the needles since buying this machine ??
Needles ought to be changed every 6 - 8 hrs of sewing, and more often with heavy or abrasive fabric.
Posted on Nov 15, 2008
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
harborsai727
SOURCE: I have a Pfaff Hobbylock 794 Serger and have lost one of the needle clamp screws. Where can I find replacements?
I lost one on my screws too. I simply went to my local Sewing machine store (in Tacoma, WA) and they ordered it for me. Got it in 3 days. Was easier to get then I thought considering how old the machine is. But they just don't make them like they used to. So, I'm holding onto my Hobbylock 794 as long as it'll keep being faithful.
Posted on Nov 25, 2012
Replacing needles on pfaff 788 serger
No worries. One needle is always lower than the other. Just make sure when installing that the needle is pushed as far as possible before the screw is tightened.
Feb 13, 2018 | PfaFF Sewing Machines
I have just snapped the needle on my Husqvana overlocker 905 how do I change the needles
The serger came with a tool just for that purpose. It may be a small screwdriver or it might be a hex or Allen wrench. Locate the screw that holds it in, insert the proper tool and turn counter clock wise until the needle will slide down, remove and replace with new needle, then tighten, clockewise the screw. You are done
Jul 05, 2014 | Sewing Machines
I am looking for where I can buy the Allen wrench for my simplicity SW432 serger. Please advise me where I can buy it. Thank you.
You can purchase complete sets of Allen wrenches in either SAE (U.S.) or Metric sizes at most hardware stores, home improvement stores, Radio Shack stores, etc. for relatively short money. If you can bring the screw with you or find out what size it is from inside your manual - you might be able to purchase only the particular wrench you need. If you can't find the size of the screw documented in your manual, you'll have to check both SAE and Metric sizes for the best fitting wrench .
Sewing machines often use very small fasteners and are precision devices through and through. Simply using a wrench that "fits" as opposed to the one that is the "correct size" will affect how many times you'll be able to loosen and tighten that screw. Using a wrench that "fits" will eventually wear out the screw head making it impossible to turn in or out, much quicker than using the correct size Allen wrench.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 05, 2011 | Simplicity Serge Pro SW432 Mechanical...
Broken needle in serger how do you remove needle
It shows you in the instruction book. I can't remember that model, but I think you need either a small Allen wrench but it may be a small flat screwdriver. Don't remove the screw, you just loosen the small set screw a turn or two to release needles, tighten the screws to hold the needles.
Jan 15, 2011 | White Sewing Speedylock 1600 Mechanical...
Hobylock 794 serger right looper needle position...I took it out to thread it and can't get it in the right position to sew correctly
I had the same problem. the last resort was go get a professional repair person. i had to replace the whole needle shaft. then the tension feeds were looked and i have never been more satisfied.
Nov 10, 2010 | PfaFF Hobby 4260
I can't find the way to change the left needle.
You can order a manual here - http://www.sewusa.com/Sewing_Machine_Manuals/Pfaff_Manuals/794_796_Hobbylock_Instruction_Manual.htm
In the meantime, contact your local Pfaff dealer. Ask if someone can help you if you bring the serger in.
Mar 18, 2010 | PfaFF Hobby 4260
Serger 794 from pfaff--calanda type 794
Nov 15, 2008 | PfaFF Sewing Machines
Pfaff hobbylock 794
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
107 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
