Question about Troy Bilt Tb70ss Gas Trimmer
Troybilt cultivator/edger starts, but dies under load
Already done: replace plug, clean carb.
Is there supposed to be a fluid in the crankcase if one opens the plug there? If so what is it? Could this be my problem?
  • 284 Answers
Yes if it is a 4 cycle
with trimmer LEVEL Take out the plug and the oil level should be at the bottom of the threads where you took the cap off.
sae 30 weight is the oil to use
It can be a problem if you have no oil in the crankcase.
Be sure your stop button is where it belongs and go thru the procedures listed on trimmer to start it
fresh gas and if it is a 4 cycle you need not to mix oil and gas for this trimmer
Posted on May 26, 2009
I have a troybilt 7000 gas generator that trips the main output breaker when under a load after 5 minutes
1. Make sure that the generator limit is not being exceeded.
2. Try checking and raising the rpm. If the engine can not sustain the load from the generator, it can/will trip the breaker.
3. If the carb is dirty or the engine runs poorly it can trip the breaker. Tune up the engine, clean the carb, make carb adjustments to correct substandard running conditions.
Jan 21, 2013 | Garden
Troybilt trimmer misfires under load, runs smooth with no load
try mixing a new batch of fuel/oil mix gas is only good for 30 days in small engines
Jul 15, 2012 | Garden
What else could cause my troybilt cultivator to not run?
spay starting fluid in the air filter if it fires then you have a carb/fuel problem (keep in mind small engines need fuel 30 days or newer )if no fire on starting fluid check for spark if you have spark good fresh fuel remove the muffler and try it again if it runs with the muffler off then open the muffler and clean the screen iside
Jun 06, 2012 | Troy-Bilt Garden
Starting mac 3227 trimmer
As you have done most things, i would suggest you have a massive air leak, either through the cylinder or crankcase gasket, or through the crank seal, i think its time to pull the whole engine down and replace these items.
May 29, 2012 | Garden
Runs good for 2-3 min, then dies
I would try using some solvent to clean the carb. It sounds like the float valve is not moving freely, therefore not letting enough fuel into the carb. Be careful though, solvent can be a bit rough on the engine, so be sure to drain it out of the fuel bowl and replace with the appropriate fuel before starting the engine.
Mar 20, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Nov 23, 2011 | Mtd Garden
The engine will not throttle up and it runs rough. Dies at an idle. Whats wrong Already changed spark plug and put new gas in
Sounds like the carb is needing a good cleaning. Get a spray can of Berryman's Carb spray cleaner.
Take the carb off and clean the carb bowl (if it's a 4 stroke motor) and remove the gas line, and with the spray tube nozzle, spray out as much of the jets, orifices, etc in your carb, let it dry out and reassemble.
Also, take the air filter/cleaner off and make sure it's clean. If it's full of dust and dirt, it will choke the carb off and it'll die at idle.
You can test this by removing the air filter element and starting the tiller. Alot of the small engines have a low oil sensing device and will shut down the engine if there is insufficient oil in the crankcase... be sure to check that too.
Let me know how it goes.
K
Aug 15, 2009 | Mantis Garden
Troybilt cultivator/tiller dies like its out of gas
it sounds like it is going to be your needle valve is stuck and need to be replace,.also your gasket may have a pin hole in it hold up to light to see if there is a hole, if so replace it..
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
309 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
