Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia tv Hi I have an olevia 32in lcd tv for about 1 year and i have sound but no picture Olevia 323, about 1.5 years old - sound, but no picture.  Cable tech thinks the "crystals" are bad (the equivalent of the picture tube?)Would this be worth fixing, or is it too pricey?
  • Olevia Master
  • 19,396 Answers
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 25, 2009
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
32in LCD Olevia TV has a picture but no sound. TV is only 3 years old. 332 model.
Hello there,
The problem with your television is the sound ic is bad and need to be replaced.To replace the sound ic you need to disassemble you television,located the television speakers,there will be a wire that connect the speakers and link it to the board where you can locate the sound ic.then you can replace it with the new one you got.
Thank for you fixya
Caseytech
Jul 01, 2011 | Televison & Video
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
Olevia tv
It sounds like a logic issue. The only way to fix it is by replacing the main board. If it is less than a year old, then it should be covered by the standard manufacture's warranty. Olevia has since gone out of business but I would still try to contact a representative to get it repaired under warranty.
Nov 08, 2009 | Televison & Video
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Olevia 26
This happened to us also. Tech support says it is a problem with the mother board power supply. Over 200 to fix plus shipping and labor costs??? Not worth it! Sounds like poor quality. Ours was just over 1 year old too. I would not take another chance on Olevia products.
Aug 15, 2006 | Olevia LT26HVX 26 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
604 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
