Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Magic chef fridge #ctb1722grq
Water overflowing from top of reservour in fridge and then dripping to the bottom and then out.how do i remedy this situation?
  • Anonymous Mar 10, 2009
    water is dripping in side magic chef freezer
Magic chef drain where is it loctaed it over flow out of refrigerator ty
Posted on Nov 22, 2008
  • 473 Answers
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Posted on Oct 21, 2007
  • Craig Shelton
    Craig Shelton Oct 21, 2007
    I have this same problem with my refrigerator so I did what fridgetech said and it solved my problem.  Thank you fridgetech.
SOURCE:
Defrosting issue or need to replace refrigerator?
If your refrigerator was manufactured in 1999, it is way overdue for replacement.
Apr 05, 2017 | Magic Chef CTF2125 Top Freezer...
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
I have a Magic Chef refrigerator and water is dropping into the vegetables section at the bottom of the fridge. What could be the cause? Thanks a lot!
There are only two reasons. 1. Water hose may be worn our or dust blocked. 2. Bottom tray of the freezer may be cracked.
Dec 08, 2010 | Magic Chef Refrigerators
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Dripping water bottom front of refrigerator
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 07, 2010 | Magic Chef CTB1722 Top Freezer...
A stream of water leaks out of the bottom of the fridge at night.
the condensate pan under your fridge has overflowed. this pan catches any condensation from the evaporator coils.
Nov 12, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Why does my magic chef refrigerator leak water on the floor
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Jun 30, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
225 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
