Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Transformer turns on but robot in water don't turn on no movemen t or water flow
I had same problem unplug unit wait for 30 seconds and try it again I had to do this 3 times this a.m. I am having problems with it only going 2 or 3 feet.
Posted on Jun 10, 2009
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
Water not going into the humifier
The first thing to check is if you are getting 24 volts to the solenoid valve, if you are and it is not opening to let the water in then u need a new solenoid vlave. If you are not getting 24 volts check to see if you are getting 24 volts at transformer, if not then turn off power to to the transformer and check itls continuity on the secondary side, if no continuity then the transformer must be replaced. Also make sure the saddle valve is open and that the inlet strainer at the solenoid valve is clean and no sediment is built up in it restricting water flow.
Jan 19, 2011 | Aprilaire 400 Humidifier
Aprilaire 400 humidifier. No water flowing to the pad. I've checked the supply -- working. Replaced the solenoid, not working. Checked the electrical to he solenoid wnen system callilng for water -- no...
Check to see if you are getting 24 volts from the transformer, if not, turn off power to the transformer and check the resistance of the secondary side, if no resistance the transformer is bad and need to be replaced. Also check to make sure all the wires are secure. If you are getting voltage at the transformer then bring power directly from transformer directly to solenoid valve and it should click open and let the water through, if it does then either the sailswitch/current sensing relay is bad or humidistat is bad.
Jan 17, 2011 | Aprilaire 400 Humidifier
I have a Watermill SS45DLV shower pump which has stopped working. Tested fuse (ok) . Tested power to transformer (ok) but not sure what voltage i should get at the pump pcb as it's not listed on the rating...
38v AC I think, similar problem here, check you have a circuit on the primary side of the transformer! If it's open you need a new transformer.
Oct 29, 2010 | Heating & Cooling
I have a genral aire 1042lh and am not getting any water to the filter. I have changed the solinoide out and restarted my unit but still no water flow yet there is ample water flow from the line when...
you must not be getting 24 volts at the solenoid, check your transformer to see that its supplying 24 volts and follow the power, also try turning up the humidistat.
Feb 06, 2010 | Humidifiers
Where is the battery compartmment for the transforming robot car from Blue Hat toy company?
The rear end has a plastic lever (with screw in center)...twist it down and flip up the piece it was blocking. And remember to turn on the switch on the fender (below the spoiler).
Dec 29, 2009 | Vacuums
We just bought a home with this humidifier installed on the furnace. There's no activity when the furnace is running. The water is connected but does not flow. Could this be a transformer problem? We guess...
Could be a couple of things. Transformer can be bad. Try connecting the two wires (usually wired red and white) from the transformer to terminal W and C on the circut board. Your bypassing the transformer and if installed a current sensing relay. The furnace transformer will/should handle the extra load. Turn on the furnace, if still not working, loosen the water supply line at the water solenoid on the humidifier, if water flows out then your supply valve isn't clogged, if no water then try screwing in the needle on the supply valve all the way in then back out. If still no water then the valve is clogged. If all is good then it looks like the water solenoid is bad or wiring to valve/humidifier control. Don't find the controls bad that often. Have fun!
Nov 28, 2009 | Honeywell HE260A1010 Whole House...
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Dec 10, 2008 | Hayward Navigator Pool Cleaner
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
378 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
