Question about Brother CS-80
I can't get the top (needle) thread to bring up the bobbin thread. It gets caught down in there somewhere
  • pittypats5 May 25, 2009
    I have no problem threading or winding the bobbin. It's when I have inserted the bobbin case in the machine and am trying to bring the bobbin thread up. I do hold on to the top thread it just disapears into the bobbin area and somehow gets caught and locks in there. I put the needle in with the flat side to the back as per the instructions.
  • 342 Answers
What is the make and model of your sewing machine? Have you made sure that the bobbin isn't in upside down? Also is the thread the same on both the spools? What size needle are you using? The thread weight has to fit the needle. It may be that the needle is to big for the thread weight, or visa versa. I believe that it is more likely that the needle is to large rather then to small though.
:) Mel
Posted on May 25, 2009
    Brigadier General:
  • 3,917 Answers
Hi
If the needle isn't picking up the thread then the problem is usually
that the needle was put in wrong (check manual for proper set of
needle.. No one has mentioned that if you HOLD ONTO the needle thread when turning
the hand wheel, you are much more likely to pick up the needle thread;
otherwise the needle thread just slips through.
Secure thread on sewing machine as if you were threading machine and pass thread end along indicated thread guides. Thread guides will be somewhat different for bobbin winding than for regular threading.
  • Step 2 Place empty bobbin on bobbin winding spindle. This spindle will be located on front right, on top right, or on either side of machine. The spindle may have to be repositioned for bobbin winding.
  • Step 3 Place thread end through one hole in upper portion of bobbin, and pull a few inches of thread through.
  • Step 4 Disengage the sewing machine needle by either pushing in the center portion of the handwheel or rotating center portion of handwheel towards you. The method will depend on the model of your machine.
  • Step 5 Take hold of the thread end and pull gently outward so that there is very little slack in the thread. Firmly grasp thread end.
  • Step 6 Push on presser foot to begin winding bobbin. Hold onto thread end while bobbin is being wound. Wind bobbin only up to guideline marked around the edge of the bobbin.
  • Step 7 Cut excess thread from the top of bobbin and cut thread that attaches bobbin to rest of thread spool.
  • Step 8 Insert bobbin into bobbin case, pass thread through indicated slots, and bring thread out a few inches to the right.
  • Step 9 Close slide plate over thread.
  • Step 10 Continue threading machine.
  • Thanks
    How to replace the bobbin casing on 4432 machine
    probably no issues with the bobbin or bobbin case but more with the needle thread tension not tight enough to make the stitch
    Oct 01, 2016 | Sewing Machines
    What is happening when I sew and 3 threads come out of the bobbin? Or when it just freezes up and I can't get the needle to go up or down?
    basically the problem comes from incorrect thread tensions
    the main thread responsible is the needle thread as the tension is far too loose
    tighten up that tension and it makes the needle on the up stroke pull the thread around the bobbin carrier and collects the bobbin thread and pulls it up to the material
    with the needle thread too loose the needle thread is wrapped around the bobbin carrier again giving you the 3 threads ( 2 needle threads and 1 bobbin thread and the tangle jams the bobbin movement
    Sep 29, 2016 | Sewing Machines
    Why is my thread getting caught under needle plate?
    try changing the needle
    make sure the thread has not come off the thread take up lever
    try turning the bobbin the opposite way
    Jan 09, 2013 | Janome Sewist 625e
    Bobbin thread is not being caught by top thread.
    rethread the machine top & bobbin
    it's also a possibilty that the machine could be out of time &
    that the machine needs to be checked at a sewing machine repair
    shop
    Aug 22, 2012 | White Sewing Sewing Machines
    Why does my thread keep breaking on my machine while i am sewing
    the top tension could be to tight
    the needle could be damaged
    try rethreading the machine just in case the thread is caught somewhere
    clean under the needle plate & bobbin area for lint or loose threads
    always make sure the top & bobbin thread tails are at least 3 to 6 inches long & pulled behind the needle to the back of the machine
    Aug 29, 2011 | White Sewing White 3032
    I just got a Vintage Singer 600E sewing machine and it came with instructions on how to thread it but not how to get started sewing. I don't know how to bring up the thread from the bobbin to start sewing....
    Hold onto the needle thread, turn the drive wheel, on the right side of the machine, until the needle goes down & back up. the bobbin thread should be caught in the loop of the needle thread. Pull it all the way out of the bobbin. and you are ready to sew.
    Patchaquilly
    May 20, 2010 | Singer Sewing Machines
    Top thread gets caught on crescent piece holding in bobbin case
    If you have the manual take a better look at how to put the bobbin in the case,
    sounds like you are putting it in wrong,
    make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
    ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
    when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
    you will get use to holding and it will get easier.
    hope this helps
    Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
    Can't bring up the bobbin thread
    Sounds like hook/needle timing is off. Check it by doing the following with the power off:
    remove bobbin, bobbin case, and needle plate.
    push needle all the way to the left.
    Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
    If not timing, clean bobbin area removing lint and thread.
    Check bobbin tension, should get slight resistance when pulling thread.
    Make sure using only Husqvarna Viking bobbins.
    Make sure the bobbin is unwinding in the correct direction.
    Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
    If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
    Good luck.
    Sep 27, 2008 | New Home HF-2022
    Brother CS-80 Logo
    186 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
